Diesel in oil Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » August 2006 » Diesel in oil « Previous Next »
4drifter
Unregistered guest
Posted From: 4.255.214.252
Posted on Tuesday, August 01, 2006 - 3:08 am:
would like help in finding where diesel could be getting in the oil. the engine is a 671 dd.runs good no smoke,
Jim Stewart (H3jim)
Username: H3jim
Post Number: 256
Posted From: 68.6.177.90
Posted on Tuesday, August 01, 2006 - 1:16 pm:
Leaking injectors.
James Stacy (Jim_stacy)
Username: Jim_stacy
Post Number: 12
Posted From: 69.208.85.134
Posted on Tuesday, August 01, 2006 - 1:38 pm:
Very often a cracked nut on the fuel tubing to the injector.
Steve N. (N4rsn)
Username: N4rsn
Post Number: 91
Posted From: 64.149.213.167
Posted on Tuesday, August 01, 2006 - 4:45 pm:
Take some of the engine oil, from the dipstick, or in the head, that is not run down, and put a drop on the top of each injector crossover line nut. (Make sure it is black engine oil). Now start the engine, (at an idle), and with the valve cover off, and watch each drop of oil, on each nut. Soon you will start to see the black oil, start to turn clear. That is the one that is leeking.
Just a thought
Steve
Tim Strommen (Tim_strommen)
Username: Tim_strommen
Post Number: 230
Posted From: 64.186.173.26
Posted on Thursday, August 03, 2006 - 12:28 am:
Might be the copper fuel supply pipes to the injectors themselves... After a long life these become brittle and crack.
Whether they are cracked or not I'd recommend replacing them any way if you pull your valve covers. They are really cheap (about $60 for that whole set on a DD 6V92). Cheap insurance, compared to a full in-frame.
Cheers!
-Tim
Post Number: 850
Posted From: 65.92.190.167
Posted on Friday, August 04, 2006 - 12:40 am:
Hello 4drifter.
I agree with Tim's thoughts of replacement for preventive maintenance, but AFTER you have found the source of the diesel.
If you start messing around before you find the leak, you might find yourself opening it up again.
Another place I saw a mechanic checking on a V6 in a GM was watching the downhill parts of the injectors that are connected to the rack. Shortly after shut down, the diesel would ever so gently start to ease down the arm. You could see it as a clearer trace in the darker oil. And it was more than one that was oozing...
Good flashlight and some patience.
And if you can't find it, don't mess up the evidence for the DD mechanic dude by taking things apart!
Let us know what happens!
4drifter
Unregistered guest
Posted From: 4.255.210.192
Posted on Saturday, August 05, 2006 - 7:41 am:
thanks for the infromation, the problem seems to be fixed,leaking fuel stands.
