Flashers on a 3751 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » September 2006 » Flashers on a 3751 « Previous Next »
Nick Morris (Nick3751)
Username: Nick3751
Post Number: 387
Posted From: 63.121.247.31
Posted on Tuesday, August 29, 2006 - 9:44 pm:
I don't know if they never had any or if the guy before me did away with 'em when he hose clamped the simi turn signal switch to the colum but I need to rewire the flashers. What kind of relays or whatever do I need to make both turn signals flash when they're supposed to and not when they're not?
Tim Hoskinson (Tdh37514151)
Username: Tdh37514151
Post Number: 181
Posted From: 4.252.65.233
Posted on Wednesday, August 30, 2006 - 9:49 pm:
Hi Nick if you are reffering to emergency flashers then no they did not have them. Only direction signals that were controlled by a lever on the right hand side of the steering columb. Remember we are having our antique truck and equipment show this weekend and would love to have your bus on display. Tim
jl vickers
Unregistered guest
Posted From: 71.52.82.62
Posted on Wednesday, August 30, 2006 - 4:47 pm:
On the PD3751 the turn siginal lever type switch was on the right side of the steering collumn down below the gear shift lever.
Lever up left hand turn siginal
Lever down right hand turn siginal
Tell tale red light flashes on and off when turn siginal is in operation located below switch.
The directional siginal flasher is located in the buzzer and relay panel assembly.
This above information is from the PD3751 maintenance manual X-4711.
This is all of the information I have on the PD3751 silverside
jl vickers
Unregistered guest
Posted on Wednesday, August 30, 2006 - 4:54 pm:
PD3751-272 history from GMC to Atlantic Greyhound Lines Charlston,WV.
bbowden
Unregistered guest
Posted From: 71.53.232.150
Posted on Tuesday, September 05, 2006 - 2:03 pm:
our 3751 has them. Top left corner of the instrument panel.
Username: Nick3751
Post Number: 388
Posted on Wednesday, September 06, 2006 - 7:19 am:
Ok guys mine has been rewired at least twice. Once I did it but once it was done before me. So now there is no relay no switch no nothing so what do I need to put flashers back on it?
Username: Nick3751
Post Number: 389
Posted on Wednesday, September 06, 2006 - 7:21 am:
