Water leak Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » September 2006 » Water leak « Previous Next »
bernie newcomb (Newk)
Username: Newk
Post Number: 2
Posted From: 64.12.116.138
Posted on Wednesday, September 13, 2006 - 6:15 pm:
i have the origanalwindows in my 4104. they have started to leak. i caulked around the windows. the leak seems to be below the window, but i can't find it-does anyone have any ideas
thanks bernie
Jerry Liebler (Jerry_liebler)
Username: Jerry_liebler
Post Number: 231
Posted From: 71.31.7.92
Posted on Thursday, September 14, 2006 - 9:49 am:
Bernie,
My windows started to leak after hard rains after I replaced the outside rubber gasket. What was happening is water was leaking through the pins that hold the windows at the bottom. Basically the outside needs drain channels through the outer gasket.
Regards
Jerry 4107
Harwood Burritt (Captwoody)
Username: Captwoody
Post Number: 2
Posted From: 151.196.119.98
Posted on Friday, September 22, 2006 - 6:27 pm:
There is a marine product called gluvit. It's a two part system about the consistency of heavy paint excellent leak repair, seeks out the leak and seals it. I use that for stubborn leaks before I apply any caulking or bedding compound.
Erston Reisch (Erston)
Username: Erston
Post Number: 1
Posted From: 64.156.190.196
Posted on Wednesday, October 18, 2006 - 5:08 pm:
Where can you buy gaskets for 4104 windows? Are they very expenisve?
~ Erston (delurking)
