Adding spring brakes Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » October 2006 » Adding spring brakes « Previous Next »
Mel La Plante (Mel_4104)
Username: Mel_4104
Post Number: 19
Posted From: 208.181.100.12
Posted on Monday, September 18, 2006 - 9:41 am:
could any one that has added spring brakes to a 4106 tell me what structal work is required to change from the single chamber air pot to the dual, and what size did you use. did you have to reweld the chamber mounting brackets? thanks in advance for your advice. mel 4104
don (Bottomacher)
Username: Bottomacher
Post Number: 139
Posted From: 72.15.81.101
Posted on Monday, September 18, 2006 - 10:32 am:
I did mine, after spending a lot of time thinking and asking about it. I believe Peter Broadribb did his, and I know Tony Gogenola had some good pictures of his. It really isn't difficult, and the results are great. You will need to weld new brackets.
Don
Username: Pvcces
Post Number: 995
Posted From: 65.74.65.54
Posted on Saturday, October 07, 2006 - 1:09 am:
Mel, a couple of cautions.
When we had ours done, on the first try, the pot had to be taken apart to remove it. When it was inspected by the garage owner, he said that it must be redone so that the pots could be removed without disassembly.
The brackets might be exposed to up to 5,000 lbs. of thrust from the pots if there is no inversion valve, so they must be sturdy enough to handle this without developing cracks.
The pots are 30/30 and I really like the setup. Good luck on your installation.
Suncatcher
Ketchikan, Alaska
