mich campbell Unregistered guest Posted From: 216.209.112.141
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 18, 2006 - 8:42 pm: | |
I have a MC8 with 4 speed manual trans, and 8V71 engine, could any of you out there tell me what type of fluids are used in the tranny, and power steering. Thanks to all |
Bob greenwood (Bob_greenwood)
Post Number: 155 Registered: 7-2006 Posted From: 4.227.116.124
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 20, 2006 - 8:50 am: | |
I can tell you that my Eagle 4 speed manual trans. uses 40 wt. motor oil & I think the power steering should use the same, this is in my Eagle book, this comes up often, & everybody wants to argue about it,the only thing that uses 90 wt is the rear end |
JR Lynch (Njt5047)
Post Number: 66 Registered: 7-2006 Posted From: 69.132.238.127
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 20, 2006 - 9:32 pm: | |
The power steering thing comes up frequently. Be sure and check the color of your PS fluid. If it's red...it's Dexron auto trans fluid (GM automotive). If it's brown, it's motor oil..40wt. The two fluids don't mix. You'll want to be certain of what you have before adding fluids. The top comes off the res easily..if you cannot see the fluid in the res window, take off the top of the res and sample your fluid. Both fluids are used, and both work well...just don't mix. JR |
Post Number: 159 Registered: 7-2006 Posted From: 4.227.115.196
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 20, 2006 - 10:13 pm: | |
is this a Richard Pryor thing,do they blow-up.they mix just fine, |
Post Number: 190 Registered: 11-2005 Posted From: 63.97.117.14
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 20, 2006 - 11:25 pm: | |
Mich, You need to get the absolutely correct info on the 4 sp. Older GMs with Spicer 4 sp like my 4104 use 50W mineral oil because they have an oil pump. Lots of people don't believe this but I have some heavy '50s GM trucks that have the same trans and also use 50W. These trans do not like 90W and it would probably be a disaster in very cold weather. I have no idea what 4 sp your MC8 has but you need to make sure. |
Post Number: 160 Registered: 7-2006 Posted From: 4.227.114.164
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 21, 2006 - 5:10 am: | |
nobody said 90w |
Post Number: 106 Registered: 7-2006 Posted From: 66.217.106.206
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 21, 2006 - 10:13 pm: | |
There's a page from the MCI manual here, providing that info! |
Post Number: 191 Registered: 11-2005 Posted From: 63.97.117.33
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 21, 2006 - 10:36 pm: | |
I don't think I said that anyone said 90W. |
