4104 History Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » October 2006 » 4104 History « Previous Next »
Kent Eubank (Rke)
Username: Rke
Post Number: 1
Posted From: 12.5.88.114
Posted on Wednesday, September 27, 2006 - 11:57 pm:
We Have a 1955(according to the title)General Moters Coach, it appears to have been converted from manual trans to an automatic.Is there anyone who can tell us about the bus's history,help identify the engine, and tell me where to look for tags or stampings to help identify the transmission(I am assuming its an allison),differential,and the devise between the engine & transmission that directs the power at an angle toward the differential(I really need a term here). The bus #'s PD4104-1399,#'s stamped on engine block 6A367024, 1067-8503
I also would like to find books on this machine,OP Manual, Repair Manual, Parts Manual
Thank's
Rke
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 176
Posted From: 4.227.114.241
Posted on Thursday, September 28, 2006 - 5:25 am:
sounds like it's a 671 detroit engine with a v.drive transmisson,either an allison or vs2 trans,parts book and service manuals are available on ebay.
Mark & Michele (Busnut_pd4106)
Username: Busnut_pd4106
Post Number: 77
Posted From: 68.213.16.189
Posted on Thursday, September 28, 2006 - 6:49 am:
Serial# 4104-1399 Date:1955 Sold to: New Mexico Transportation Co.
Source: http://www.geocities.com/buslist/Delivery/PD4104/pd4104_5.html
Manuals Available for GMC PD4104
http://www.coachinfo.com/Manuals/Coach/GMC/4104.html
Username: Lsilva
Post Number: 39
Posted From: 71.30.249.23
Posted on Thursday, September 28, 2006 - 7:58 am:
I see that 1405-1408 went to Cuba. Wonder if they're still in service?
Len
Kent Eubank (Rke)
Username: Rke
Post Number: 2
Posted on Thursday, September 28, 2006 - 8:45 am:
Thank You all for the info.
can anyone suggest a safe way to work underneath the bus,would ramps of some type be acceptable?
Kent
Post Number: 177
Posted From: 4.227.112.147
Posted on Thursday, September 28, 2006 - 9:58 am:
ramps.... ?? you are working on heavy equipment, jack it up, put railroad ties or cement blocks under it,block it up good....once it falls on you,you go to meet Elvis
Username: Rjlong
Post Number: 1033
Posted From: 71.195.113.23
Posted on Thursday, September 28, 2006 - 10:09 am:
Kent -
To add to what Mark posted:
The differential is a Timken unit, which has been absorbed into Rockwell/Meritor.
The angle stuff is known as a "bevel gearset".
To better ID the transmission: If it's got a big, bowl-shape to it just inside the chassis side access door, it's probably a V-730. If the big round end is flat-bottomed, it's probably a VS unit. Either way, there should be a stamped ID plate on the side of the gearbox.
Also, if you call your local Detroit dealer with the engine and transmission ID number, they can tell you exactly what it is, and what they have in their records as to how it was originally configured.
Lots of busnuts use ramps to get under the coach - just build them sturdy enough to support 15 tons!! Also, build them long enough so you've got more of a gentle slope to climb, with a plenty of room on top for the wheel. Some kind of "stops" at the end to keep from running off is a good idea, too.
Welcome to the madness!
HTH. . .
Username: Sylverstone_pd4501864
Post Number: 200
Posted From: 216.173.223.253
Posted on Thursday, September 28, 2006 - 10:30 am:
i use a pair of railroad ties beveled at one end so i can just drive up on 'em.
they are *heavy*, but they get the job done.
i didn't have 'em with me on my trip to lukes (us coach in berlin, nj). i was on my way back, and wasn't going to make it all the way back to seattle without putting gear oil in the rear end.
ended up at the seediest truck stop i have *ever* seen... had to add gear oil to a leaking rear end (seals) on the way back...
this is when i had the dubious pleasure of airing up the bus, sliding under it, having a friend hand me a couple of gallons of gear oil down the alternator access hatch, fighting about a gallon into the rear end, then having to have my lady start the bus to air it up enough so i could get back out from under it. :/
i've got a scenicruiser, so there's plenty of room for *me* under it when the bags are flat, but getting in and out is a serious lesson in gymnastics with no air. the entire time i was very aware of where i could and couldn't be, but frankly, a set of ramps would have been much much better. :/
-dd
Username: Kyle4501
Post Number: 201
Posted From: 65.23.106.193
Posted on Thursday, September 28, 2006 - 3:54 pm:
dd, My cruiser came with steel tubes to put under the suspension bumpers to keep the bus up while working on it (even if a bag blows out). They are ~1/4" wall & the ID clears the rubber bumper. I have also used wood blocks (& I have seen some get crushed too, so I like the steel tube better).
Ramps are fine, just be sure they are sturdy & on solid ground. Amazing how easy it is for a bus to mash something into the ground, BTDT.
Solid lumber with small/ no knots is best.
Kent Eubank (Rke)
Username: Rke
Post Number: 3
Posted on Thursday, September 28, 2006 - 11:20 pm:
Thanks Bob, I never was that big an Elvis fan, and I am in no hurry for that concert.
Mark, The web pages are very informative THank's
RJ, the old girl has a big round end with no flat spot. This bus thing gets more interesting
all the time.
By-the-way, am looking for reputable bus repair buisness, or mechanic. And someone who works on the RV, or conversion portion of the bus.
Thank's Much
Kent
Username: Lsilva
Post Number: 40
Posted on Friday, September 29, 2006 - 8:49 am:
Many years ago, RJ told me that my 4104-1559 went to Scenic Hiway Tours in California. That made sense since I could see the name under the paint on the side.
The list posted above
shows it going to Modern Coach Corp in Georgia.
Any idea why the confusion?
Len
jl vickers
Unregistered guest
Posted From: 71.52.82.62
Posted on Thursday, September 28, 2006 - 9:21 am:
The home office for New Mexico Transportation Company was Roswell,NM.
New Mex.had a lot of GMC in their fleet over the years 4103,4104,4106 and 4107's.
They were part owned by Greyhound at one time that is why you would see the New Mex equipment with Greyhound dogs on the side of their coaches.
TNM&O bought New Mex and it was merged into their system.
I do not know the date of the buy out but it was after New Mex had the later MCI's in their fleet.
jlv
Austin Davis (Zimtok)
Username: Zimtok
Post Number: 4
Posted From: 63.94.78.194
Posted on Monday, October 02, 2006 - 1:20 pm:
I looked at the buslist site and cannot find my 1960 4104 bus.
The serial number of my bus is PDY1044971.
Where else might they have a list of busses and their history?
Username: Dmd
Post Number: 89
Posted From: 71.125.61.22
Posted on Monday, October 02, 2006 - 8:09 pm:
Austin, I bet its PD 4104 4971 P is for parlor Dis for diesel then the model and #
Dallas (Dal300)
Username: Dal300
Post Number: 122
Posted From: 172.163.114.81
Posted on Monday, October 02, 2006 - 9:49 pm:
Austin,
You could go to the MAK board and see if JL Vickers (Roadrunnertex) can give you a history of your coach.
Username: Rjlong
Post Number: 1034
Posted From: 67.181.163.170
Posted on Monday, October 02, 2006 - 10:14 pm:
Austin -
PD4104-4971 was delivered new in July of 1960 as fleet number 613 to Great Southern Coaches, based in Jonesboro, AR.
HTH. . . :-)
Username: Zimtok
Post Number: 8
Posted on Tuesday, October 03, 2006 - 8:35 am:
Thanks everyone...
I'm just outside Memphis TN, so Jonesboro AR makes sense.
Is there anyway to track where it went through its life?
I am the recent co-owner, only 6 weeks. It was owned by a Gospel Group for 20+ years prior to us. And very well taken care of. Prior to that I don't know.
Username: Niles500
Post Number: 667
Posted From: 24.129.157.205
Posted on Wednesday, October 04, 2006 - 11:26 am:
Gotta a funny story 'bout Jonesboro ......
Username: Zimtok
Post Number: 16
Posted on Wednesday, October 04, 2006 - 11:30 am:
Don't leave us in suspense....
Go on and tell us the story.
Username: Dmd
Post Number: 91
Posted From: 71.125.20.114
Posted on Wednesday, October 04, 2006 - 9:25 pm:
Hey Austin, I'm from Brighton Tn. 35m North of Memphis. 4104's are good looking, nice coaches. Good luck, Dave and Dori.
Username: Zimtok
Post Number: 18
Posted on Thursday, October 05, 2006 - 8:41 am:
Thanks Dave & Dori,
I'm in Oakland Tn 10m east of Memphis.
Dallas (Dal300)
Username: Dal300
Post Number: 129
Posted From: 172.128.55.212
Posted on Thursday, October 05, 2006 - 12:37 pm:
Hey, Dave, Dori and Austin!
Since your in Tennessee, are you going to be able to attend Busted Knuckles Tn. Bus Bash at the end of the Month????
Support Your local Busnut!
Dallas
Username: Zimtok
Post Number: 19
Posted on Thursday, October 05, 2006 - 1:46 pm:
UM.... NOT SURE....
Where - when - does it cost anything?
