Kent Eubank (Rke)
Registered Member Username: Rke
Post Number: 4 Registered: 9-2006 Posted From: 12.5.88.114
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 01, 2006 - 4:04 pm: | |
Does any one know whitch gass charged bay door supports work well on the 4104, also on the engine compartment door? I was going to change differential oil, would 85-140 GL5 the type to refil with? Kent |
Bob greenwood (Bob_greenwood)
Post Number: 191 Registered: 7-2006 Posted From: 4.227.115.51
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 01, 2006 - 7:08 pm: | |
yes on the diferential |
Denis (Denis)
Registered Member Username: Denis
Post Number: 4 Registered: 11-2005 Posted From: 70.39.39.201
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 01, 2006 - 9:46 pm: | |
Kent, Scroll down to 9-21-06 Thread "Bay door hinges" Ed has the answers for your supports. |
Larry D Baker (Lbaker4106)
Registered Member Username: Lbaker4106
Post Number: 41 Registered: 5-2005 Posted From: 209.153.174.157
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 02, 2006 - 10:24 am: | |
I just installed gas springs on my large bay doors of my 4106. I used part# H 9504-150 which I got from International Bus & Parts. Phone 1-800-468-5287 and ask for Rich. I would like to install them on my engine door but I don't know the pressure rating. By the way the 150 in the part number is the pressure. |
Post Number: 1694 Registered: 1-2001 Posted From: 75.108.82.163
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 02, 2006 - 12:56 pm: | |
FYI, Rich is no longer at IBP. He is in Tennessee with Prevost now. Here is a link to the last post of his that I have seen: http://www.busconversions.com/bbs/index.php?topic=1907.0 Richard (Message edited by drivingmisslazy on October 02, 2006) (Message edited by drivingmisslazy on October 02, 2006) |
Post Number: 201 Registered: 11-2005 Posted From: 63.97.117.14
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 04, 2006 - 11:46 pm: | |
Larry, I installed air springs from an '88 Dodge mini van hatch on my 4104 engine door, fit perfectly into the old support mounts. I happened to have two used ones on hand and tried them just for kicks-amazing! How many times will this happen? You can buy these things almost anywhere. I think I got mine at WalMart for $15-20 apiece. I have to push to close it, one almost holds it up. My only complaint is that the door is not high enough to lift over my head but neither was the original. Do your baggage doors lift up to the same angle as with the original supports? What are the bolt to bolt center closed and open measurements on your baggage door air springs? I would like to support mine also. Also where are the springs mounted in inches from the door top? These measurements would save me a lot of time experimenting. |
