Bus Air cycles between 120 & 114 lbs Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » November 2006 » Bus Air cycles between 120 & 114 lbs « Previous Next »
Prather Ellsberry (Prather)
Username: Prather
Post Number: 1
Posted From: 207.69.137.207
Posted on Tuesday, October 31, 2006 - 8:51 am:
Bus air started cycling between 120 & 114 lbs, changed governer, same problem. I have a AD 2 air dryer, thinking now this may be the problem. Has anyone had this problem and what was the fix.
Thanks in advance for any help.
Prather
Post Number: 935
Posted From: 65.92.191.246
Posted on Tuesday, October 31, 2006 - 4:30 pm:
Hello Prather.
The cut-in and cut-out points are determined by the air compressor governor.
The air dryer does as it is told by the governor.
Unusual that a new governor is not showing you somewhere 20 to 25 lbs between cut-in and cut-out.
Who else has an idea?
Chuck Lott (Chuckmc8)
Username: Chuckmc8
Post Number: 186
Posted From: 72.152.148.123
Posted on Tuesday, October 31, 2006 - 9:07 pm:
Prather, go to the Bendix web site...WWW.Bendix.com, the contact info will have a toll free phone # to the bendix tech help line. Call them and tell the tech whats going on and what you've tried.
Bet they can help. Always nice folks. HTH, Chuck
Username: Chessie4905
Post Number: 335
Posted From: 71.58.126.56
Posted on Tuesday, October 31, 2006 - 10:16 pm:
Make sure that the problem isn't a faulty gage before you spend a lot of time on the problem. Cycling..... do you mean cutting in and cutting out? Is it holding pressure when it hits 120 or is there an air leak causing it to drop right away? The 114 could be the gage sticking on it's way down and is actually getting down to 105 before kicking in. Try tapping the gage at 114 and see if it jumps down to 105.
Username: Prather
Post Number: 2
Posted From: 207.69.139.9
Posted on Thursday, November 02, 2006 - 8:44 am:
Called the Bendix Tech. He said two things to check were the inlet pressure to the governer, if that wasn't the problem to spray some WD 40 on the unloader valves located in the air supply to the compressor.
Put a gage in line to the air supply to the govener, compressor was working as it should, unloading at 120 lbs started compressing again at 105 lbs.
So I have a air leak somewhere. After shutting off engine and letting air decay off for about 20 minutes, still had 119 lbs on gage at dash and 0 lbs on gage at compressor.
So I am searching for the air leak, my old ears makes it tough, can't hear it but know it is some where.
Thanks for all the input.
Username: Rjlong
Post Number: 1095
Posted From: 67.181.163.170
Posted on Thursday, November 02, 2006 - 11:20 am:
Prather -
Got a fifth or sixth grade boy in the neighborhood? Grandson maybe?
If so, see if they can hear the air leak and help you trace it.
If not, time to break out the spray bottle with soapy water!
FWIW & HTH. . .
Post Number: 337
Posted on Thursday, November 02, 2006 - 5:11 pm:
Another option would be to use a mechanic's stethoscope with the metal tip and amplifier removed, listening through the hollow tube. Works for larger leaks that you can't hear.
Phil Smith (Phil_smith)
Username: Phil_smith
Post Number: 32
Posted From: 24.117.40.105
Posted on Friday, November 03, 2006 - 7:23 am:
I think it's the Dash gauge sticking or defective.
Just another opinion from the peanut gallery !
Phil in Az.
Username: Gusc
Post Number: 226
Posted From: 63.97.117.41
Posted on Friday, November 03, 2006 - 10:18 pm:
Sometimes air gages get moist and rust at the inlet hole which is very small to start with. Happened to me.
Username: Prather
Post Number: 3
Posted From: 207.69.137.202
Posted on Sunday, November 05, 2006 - 9:47 am:
It was the AD-2 dryer, specifically the dryer outlet check valve was leaking.
Prather
Post Number: 937
Posted From: 70.48.195.211
Posted on Wednesday, November 08, 2006 - 8:08 pm:
Hello Prather.
If the system reached cut-out, when the governor signals the air dryer to purge, the line from compressor to air dryer purges along with the volume inside the air drier.
The line beyond the drier, towards the wet tank, should stay pressurized.
If the compressor is still cut-in when you shut down, and the line leaks out the air drier purge valve, there is a problem with the purge valve.
If the wet tank pressure drops over time when the compressor is cut-out, and the rest stays pressurized, the air drier valving is suspect.
The AD2 is a fine drier, and rebuild parts are readily available.
Username: Prather
Post Number: 4
Posted From: 207.69.136.204
Posted on Thursday, November 09, 2006 - 7:21 pm:
Buswarrior
I don't know about all that but when I discovered the check valve was leaking back into the Dryer I just got a rebuilt AD2 and everything works fine now.
Prather
Post Number: 938
Posted From: 64.228.91.228
Posted on Friday, November 10, 2006 - 9:55 am:
That works!
