Paso One (Paso_1)
Registered Member Username: Paso_1
Post Number: 74 Registered: 11-2004 Posted From: 142.165.246.239
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 02, 2006 - 4:34 pm: | |
Hey Bob can I remove the switch on the 6.5 NH and extend the wiring 24 to 30 inches without any issues. I can't seem to find a remote wire harness that would just plug into the box. I was thinking if I just popped the switch out and lengthen the wires. Then tape off the old hole. thks Paul |
Post Number: 278 Registered: 1-2005 Posted From: 72.40.15.79
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 02, 2006 - 7:08 pm: | |
Paso http://www.bdub.net/manuals/Onan/Onan6kwNH_Major-Service.pdf look at page 51 and 54 Hope that helps Pete RTS/Daytona Gee those Classic GMC Guys have their act together - (I used to be one) - regular cult following - loved mine - got too small 26' - now I have its big brother a 35' RTS see--> http://www.bdub.net/manuals/index.html (other GMC M/H manuals / info / etc or check out--> http://users.california.com/~eagle/ everthing you ever wanted to know about GMC M/H |
Paso One (Paso_1)
Post Number: 75 Registered: 11-2004 Posted From: 142.165.246.239
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 02, 2006 - 9:51 pm: | |
Perfect Thanks Pete! |
Post Number: 26 Registered: 7-2006 Posted From: 4.240.214.66
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 03, 2006 - 12:07 am: | |
Thanx,Pete....been looking for the information you posted on Onan.....thanx very much. RCB |
Bob Wies (Ncbob)
Registered Member Username: Ncbob
Post Number: 193 Registered: 2-2006 Posted From: 72.71.71.140
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 03, 2006 - 3:34 pm: | |
Paul, you could add a second switch in parallel with the original by using terminals 1,2,& 3 in the controller or on the Board. 1 goes to the center terminal of the new switch, 3 goes to start, and 2 connects to the stop terminal. That way you can keep your existing switch and mount your remote start switch wherever it's convenient for you. NCbob |
Paso One (Paso_1)
Post Number: 76 Registered: 11-2004 Posted From: 142.165.246.239
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 03, 2006 - 7:16 pm: | |
Thanks Bob With your explanation and the wiring diagram that Pete linked it should be a no brainer didn't think to wire it in parallel. I do have a second switch so I'll hook it up this weekend. thanks Guys. |
Post Number: 279 Registered: 1-2005 Posted From: 72.40.12.2
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 04, 2006 - 7:33 am: | |
you can add as many parallel switches as you need - Pete |
Paso One (Paso_1)
Post Number: 77 Registered: 11-2004 Posted From: 142.165.246.239
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 04, 2006 - 6:47 pm: | |
Well that was one quick and easy job. Never even dawned on me to put a second switch in. That is another good thing about the boards thanks guys. Pete when I was reading one of the links you attached I read about another mod that was interesting putting a toggle switch to activate fuel pump prior to cranking. I think I might do that as well it can't hurt knowing there is fuel at the carb when you it start. |
David (Davidinwilmnc)
Registered Member Username: Davidinwilmnc
Post Number: 141 Registered: 7-2005 Posted From: 71.77.223.78
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 06, 2006 - 10:37 pm: | |
Often, these remote harnesses are on eBay. I've seen 'em many times, but have never needed one. David |
