Don Nichols (65fisher)
Registered Member Username: 65fisher
Post Number: 1 Registered: 11-2006 Posted From: 67.141.149.169
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 30, 2006 - 9:43 pm: | |
I have a 1965 GMC "Fishbowl". It has the 318 Diesel and the Vs2-8 tranny. I cannot get it to move. It appears to go into gear and I can rev the engine, but nothing happens. I am extremely new to this, so be gentle, but I really need to move this bus. Thanks for the help. Don |
Post Number: 132 Registered: 7-2006 Posted From: 66.217.106.170
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 30, 2006 - 9:59 pm: | |
Is it safe to assume you've managed to properly released the parking brake, and the brakes have indeed released? |
Bob greenwood (Bob_greenwood)
Post Number: 398 Registered: 7-2006 Posted From: 4.227.2.41
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 30, 2006 - 10:26 pm: | |
we don't know how new you are, but you must push the button down,then press hard on the brake pedal after you are sure you have 120 pounds of air |
Steve Souza (Steveggt)
Registered Member Username: Steveggt
Post Number: 1 Registered: 12-2006 Posted From: 71.116.87.220
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 01, 2006 - 12:41 am: | |
Hi Don! If you're in gear but the bus doesn't move, you should feel it rock back and forth a bit. This means your brakes haven't released. You probably have a F-N-R lever to the right of the driver's seat, or you might have a toggle switch on the left of the dashboard next to the air gauge to select F-N-R. With the lever, a cable pulls the tranny into F-N-R. With the toggle, an air cyliner/piston selects F-N-R. In either case, once the desired direction is selected, there's about a 1 second delay, then you should feel the trans engage. It's just like your car...there's a bit of a delay from when you select (D) Drive to when it actually engages. If you don't hear/feel the little "clunk", the tranny isn't engaged, and then we have to dig deeper... |
Art Gill (Sandcastle)
Registered Member Username: Sandcastle
Post Number: 19 Registered: 5-2004 Posted From: 208.11.184.64
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 01, 2006 - 7:54 am: | |
Try pulling up on the brake pedal. I have had mine stick enough to keep the brakes engaged. Art |
Brian Brown (Blue_velvet)
Registered Member Username: Blue_velvet
Post Number: 402 Registered: 6-2005 Posted From: 72.19.152.144
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, December 02, 2006 - 2:01 am: | |
As Steve said, you should hear the "clunk". When I had a Fishbowl w/ the VS2-8, sometimes the wire that connects to the tranny solenoid would come off. Was an easy fix. One time it came off when I was negotiating a tight turn with several iterations backwards and forwards. So I ran back there to plug it in and FELT THE CLUNK the instant I did... it was still in DRIVE! Luckily I caught up with the bus, since you've never seen a man cover 40+ feet so fast! Brian "stupid bus tricks" Brown presently driving a 4108-216 w/ V730 Longmont, CO |
