John Zabrocki (John_z)
Registered Member Username: John_z
Post Number: 22 Registered: 9-2006 Posted From: 64.61.224.23
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 25, 2006 - 3:01 pm: | |
I have removed the thermostat housing (6-71) to check the thermostat. Engine will not go over 150 or so, and it takes half an hour on the freeway to reach that. Any tips for getting the thermostat out of there so i can test it out? TIA |
Post Number: 130 Registered: 10-2004 Posted From: 71.125.9.251
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 25, 2006 - 5:53 pm: | |
John, did the stat atay in the cover with the outlet or in the stat housing? look carefull some are 2 piece covers, you might have to pry them apart. |
Douglas Wotring (Tekebird)
Post Number: 40 Registered: 10-2004 Posted From: 69.136.90.146
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 25, 2006 - 6:45 pm: | |
all 4104's came with dual stats....operating oposite of each other........this allows the coach to produce heat for the passenger comfoprt asap |
Post Number: 23 Registered: 9-2006 Posted From: 64.61.224.28
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 25, 2006 - 7:06 pm: | |
Hi David, the stat stayed in the housing on the block. The end cover came right off, but the stat is stuck in there pretty darn good. Doug, yes, the bypass stat is on the curb side of the bus. I also tried to remove the cover here, thinking i could then try to persuade the main stat on the driver side to pop out. But after removing the nuts, i cannot yet get the stat housing/cover to come off. I guess tomorrow out comes the torch and try some heat. Any other ideas out there? |
Post Number: 41 Registered: 10-2004 Posted From: 69.136.90.146
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 25, 2006 - 7:10 pm: | |
whatever you do don't break it....it's an 04 only part that is made of unobtanium.......and you missed santa this year now. |
Post Number: 24 Registered: 9-2006 Posted From: 64.61.224.28
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 25, 2006 - 7:52 pm: | |
Thanks Doug, whatever i try with it, i WILL be careful. But i have to get those 2 stats out of there,,, i need to get them fixed so it will run at the correct temp. Thanks again. |
Bob greenwood (Bob_greenwood)
Post Number: 503 Registered: 7-2006 Posted From: 64.136.49.228
Rating:  Votes: 1 (Vote!) | Posted on Monday, December 25, 2006 - 7:57 pm: | |
Didn't your 4104 come with shutters ? |
Post Number: 263 Registered: 11-2005 Posted From: 206.40.238.26
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 25, 2006 - 10:42 pm: | |
John, I had the same problem when I first got my 4104. I discovered that my radiator shutter valve was closed because it was leaking air. I fixed the leak, turned it on and now it runs 180-190* in all weather. Do yourself a favor and check this out first. |
Post Number: 25 Registered: 9-2006 Posted From: 64.61.224.242
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 25, 2006 - 11:13 pm: | |
Bob, no my bus does not have the shutters on it. It is just open in from of the radiator. I have no idea when or why they would have been taken off. Gus, are you talking about your shutters staying open all the time, and that keeping the engine cold? |
Post Number: 367 Registered: 10-2003 Posted From: 71.58.126.56
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 26, 2006 - 6:05 pm: | |
Because the shutters are missing, it will be difficult for the engine to maintain correct heat, especially in cooler weather. You will need to obtain and reinstall a set of shutters or fab up a declutching fan setup, which would be a bigger PITA than reinstalling the shutters. See Luke or Dean's coach to get the parts you need.My 04 will act the same way if the shutters are open all the time. |
Post Number: 266 Registered: 11-2005 Posted From: 65.138.63.139
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 27, 2006 - 12:58 am: | |
John, Yes, mine were open all the time until I discovered the closed air valve. Since you have no shutters I would recommend, along with the others, that you get some. As many 4104s as there are around you should be able to find some. Those things are great. Otherwise you need to cover the radiator. |
Post Number: 26 Registered: 9-2006 Posted From: 64.61.224.223
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 27, 2006 - 3:17 am: | |
John and Gus, thanks for the info on the shutters. It would seem then that all that is wrong with my bus is the missing shutters. I never did get the main engine stat to come out, and i never did get the bypass stat cover to come loose. So today i put it all back together. And i never broke anything! For now, it will have to be a piece of cardboard hanging in front of the radiator. Hope to track down a shutter system i can afford at some point in the future. Thanks again for the help guys. |
Post Number: 507 Registered: 7-2006 Posted From: 64.136.49.228
Rating:  Votes: 1 (Vote!) | Posted on Wednesday, December 27, 2006 - 10:20 am: | |
don't know if you could find it...but I had a 1958 volvo that had a screen much like a window shade that was adjustable from inside,that went in front of radiator Glad you are leaveing the thermostats alone,they were not the problem |
Post Number: 269 Registered: 11-2005 Posted From: 65.138.61.60
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 27, 2006 - 6:31 pm: | |
John, You were lucky, I would have broken something for sure! Bob has a good idea if you can think of some way to move it from the front. In cold weather you should be able to get away with covering most of the radiator full time, diesels really run cold in cold weather. I used to cover 90% of an Int 18 wheeler and it still ran cold but covering it completely was not allowed. |
Post Number: 509 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 27, 2006 - 7:18 pm: | |
I'd start out with covering 20%....overheating a 2 cycle doesn't work |
Post Number: 27 Registered: 9-2006 Posted From: 64.61.224.51
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, December 30, 2006 - 2:19 pm: | |
Thanks again guys. I guess for the time being i will use a piece of rubberized mat hanging in front of the radiator. I will be able to roll it up or down to adjust how much air is allowed. After all, i bought the bus to escape to warmer cilmates eventually. For the next year or so, i doubt i will put that many miles on it during the winter. I do appreciate your help! |
Post Number: 514 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, December 30, 2006 - 2:57 pm: | |
Lots of people from minn. down here, 68 today,78 tomorrow, when you get a two-cycle to 180 she's happy...above or below that...she ain't... HI FROM HARLINGEN ,TEXAS |
