Exterior Skin Replacements Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » January 2007 » Exterior Skin Replacements « Previous Next »
John Wardell (Hitherandyarn)
Username: Hitherandyarn
Post Number: 1
Posted From: 148.64.18.116
Posted on Thursday, January 11, 2007 - 4:00 pm:
I'm looking at a 1983 MC9. It's in very good condition physically and mechanically, except for missing the exterior skin on the left rear quarter. The side panels have been removed from the windows down, from the drive axle to the back.
I'd like some opinions on the best way to process to replace them.
Bill Glenn (Homegrowndiesel)
Username: Homegrowndiesel
Post Number: 20
Posted From: 68.162.69.148
Posted on Friday, January 12, 2007 - 11:04 pm:
OK, Hit Her And Yarn?
Aluminum, Steel, Fiberglass all easy, heat them all up as you rivet them in place.
Original was aluminum. You can buy 10' lengths, .040.
Douglas Wotring (Tekebird)
Username: Tekebird
Post Number: 53
Posted From: 69.136.90.146
Posted on Friday, January 12, 2007 - 11:48 pm:
1st question: Why did they de skin it?
all the parts are avail new and used.
Robert & Debra White (Rob_n_deb)
Username: Rob_n_deb
Post Number: 8
Posted From: 24.116.249.100
Posted on Saturday, January 13, 2007 - 12:37 pm:
Bill, I have a question for you. you stated "heat them all up as you rivet them in place" heat what up and where,,,I am confused to why you would heat them up, I have replace many sections of Aluminum skins on aircrafts and never did we heat them up,,,thats why I am asking,we're still pondering about caps front and back for our mci when we buy it this year,,thanks for your information,,,Rob n deb
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 544
Posted From: 64.136.49.228
Posted on Saturday, January 13, 2007 - 1:54 pm:
I think the heating is silly too,I've been around airplanes & trucks & busses & it's just some old wives tale that somebody started.
norcal kyle (Kylexisxrad)
Username: Kylexisxrad
Post Number: 107
Posted From: 75.44.207.92
Posted on Saturday, January 13, 2007 - 5:03 pm:
call international bus and parts. www.1800intlbus.com OR 800-INTL-BUS.
Ross Carlisle (Rrc62)
Username: Rrc62
Post Number: 165
Posted From: 67.142.130.35
Posted on Saturday, January 13, 2007 - 5:33 pm:
When you replace aircraft skins, you replace relatively small panels that are usually formed in one way or another (I've done a few myself). When you do a bus skin, you are installing a single, flat panel 10 feet long. If you rivet it in place cold and it gets hot later, it will epand and buckle. If you heat as you go, the skin will be in it's expanded state when you rivet and will not buckle when the noon sun heats it up.
If you don't believe it, rivet one panel on cold and one hot, then put both out in the hot sun and see what happens. If you can't heat the skin by some mechanical means, at least let it lay in the sun and get warm before riveting it on.
Ross
Post Number: 546
Posted on Saturday, January 13, 2007 - 6:22 pm:
I've been in a plant that makes airplane wings,for big airplanes,no little panels there,no heating either
It took me & one ironworker 8 hours to do the windows on my bus,800 holes & 800 pop rivits,supposed to keep the metal hot for 8 hours??,silly silly people
Username: Rob_n_deb
Post Number: 9
Posted From: 166.137.97.28
Posted on Sunday, January 14, 2007 - 5:21 pm:
I am more confused now before I asked that question...wow heat it up in the sun....sounds so unreall..ok I replace a small section of skin on a airbuss A400 or A300 it was a few years ago it was 4 feet x 16 feet we did not heat it up...the fuselage will and does expand when Pressurize....the skin expans and contract thuss moving the skin back inforth on the rivets known as a Working Rivet...I have never seen a buckled skin before unless it was damaged by some sort of impact..my thought about all this now is the lack of sufficient rivets and proper spacing... theres my 2cents worth..
Username: Ace
Post Number: 442
Posted From: 75.201.52.181
Posted on Sunday, January 14, 2007 - 6:59 pm:
If you look at most all the newer high end prevost coaches you will see that very little if any heat is applied to the sides when constructed because after they hit the road, they are all wavy looking. I think personally from knowing what metal does when heated and cooled that it would just make a better appearance more so than structural!
I guess it really depends on what YOU are looking for as in final appearance! Keep in mind that if you DON'T choose to pre heat the metal that a wavy "look" COULD, but not necessarily occur! Time, weather, and material used will make all the difference!
Ace
Steven Goodwin (Flynbanjo)
Username: Flynbanjo
Post Number: 1
Posted From: 71.99.204.5
Posted on Sunday, January 14, 2007 - 9:45 pm:
Just to add a thought. Have you considered the laws of thermal expansion.
Temperature Change X Coefficient of thermal expansion = ____________ X linear inches.
example:
If the change in temperature = 50 degrees
Coefficient of thermal expansion for aluminum = .00001244 (dependent of the alloy)
Then:
50 X .00001244 = .00062
.00062 X 120in = .0744in or a little more than a 1/16in per 10 feet of aluminum
It may not be a lot but it does show that the metal is growing.
Username: Ace
Post Number: 444
Posted From: 70.212.168.62
Posted on Sunday, January 14, 2007 - 11:29 pm:
Yea and the more movement you have the more rivets you will lose in the end!
Don't ask how I know that but my GMC and Eagle both suffered from lost rivets due to expansion!
I didn't cover those windows though! :-)
Ace
