H8H-649 speedo question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » January 2007 » H8H-649 speedo question « Previous Next »
Chris Smith (Catfish)
Username: Catfish
Post Number: 11
Posted From: 172.128.22.252
Posted on Thursday, January 18, 2007 - 11:34 pm:
Mine has a Tachograph and would like to change over to a speedometer.Also I would like to add a tach while I'm messing around in the dash
Username: Rjlong
Post Number: 1163
Posted From: 71.195.127.101
Posted on Thursday, January 18, 2007 - 11:41 pm:
Chris -
What type of tattle-tale do you have in the dash? One of the grey square ones hinged on the side, or a black round one hinged at the bottom?
I think I may know of someone who's looking for one, if it's the round model.
As for replacing the speedo, most folk are using an electric one that's driven from the LF wheel. Same for the tach - an electric one driven from the alternator.
I can't remember specific brands right now, but if you do a search of the archives (at the bottom of the page or in the upper RH corner), the info will come up, as this has been discussed many times over the years.
Don't forget that this is 24VDC stuff, unless you step it down.
FWIW & HTH. . .
Username: Catfish
Post Number: 12
Posted on Thursday, January 18, 2007 - 11:49 pm:
it's the square one hinged at the side. Would I be able to take the speedo and sending unit from a 4106 and use it? or would be better just to find an aftermarket
Username: Pete_rtsdaytona
Post Number: 298
Posted From: 72.40.3.153
Posted on Friday, January 19, 2007 - 8:57 am:
Chris
Give me a call ***386*672*0571*** or email me at hawk_ii_mail ***at***yahoo.com
I have salvaged Monaco Tach and Speedo for $39 each - the speedo will work off the front wheel pick-up and the tach can hook to the "R" terminal of a 50DM alternator - If you do not have a front wheel or drive shaft pulser - I have Drive shaft pulsers for $25 from Rostra Cruise Controls
Pete
