Chuck Brush (Chuckbrush)
Registered Member Username: Chuckbrush
Post Number: 14 Registered: 1-2007 Posted From: 64.12.116.138
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 2:18 am: | |
I am trying to find the part that regulates the pressure for the air brake system. Is the horizontal cylinder shaped thing behind the air intake hose and just above the rocker cover it? http://tinyurl.com/ypblj3 If not, then what does anyone suppose that thing is, and where might I look for the air pressure regulator? Thanks, Chuck |
Bob greenwood (Bob_greenwood)
Post Number: 582 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 3:39 am: | |
it's called the D-2 air govenor...it's on the side of the air compressor,has two bolts holding it on, looks like a rocket ship. |
Duane Bratvold (Connieandduane)
Registered Member Username: Connieandduane
Post Number: 33 Registered: 10-2006 Posted From: 205.242.83.12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 9:44 am: | |
Hey Bob. Since I got the 4104 home I noticed oil driping out of the air throttle actuator. I talked to Father in law and he said he has changed the air compressor twice in the last year to try and stop it. Is there any other place oil could get in other than compressor seals? |
Tim Hoskinson (Tdh37514151)
Registered Member Username: Tdh37514151
Post Number: 204 Registered: 9-2004 Posted From: 4.224.234.184
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 10:00 am: | |
Hi Duane if your bus has had a compressor push oil into the system it may take a while to get it all out as the air movement will push the oil through out the system. Make shure you have drained all air tanks and repeat draining them to remove as much oil as possible. Chuck as Bob mentioned most compressors have the air governor mounted right to the head of the compressor but not all some are remote mounted on the fire wall. These are found on older buses and trucks but are usually removed and replaced by the later compressor mounted style. You may also be looking at the system dryer look at the bottom to see if there is a drain valve (Message edited by tdh37514151 on January 23, 2007) (Message edited by tdh37514151 on January 23, 2007) (Message edited by tdh37514151 on January 23, 2007) |
Post Number: 16 Registered: 1-2007 Posted From: 152.163.100.138
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 12:07 pm: | |
I posted a photo of what I am looking at. Is this perhaps, the remote version of an air regulator? Here is a link to my yahoo briefcase where the photo is: http://tinyurl.com/ypblj3 Thanks, Chuck |
Post Number: 1170 Registered: 12-2000 Posted From: 71.195.127.101
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 6:54 pm: | |
Chuck - The link doesn't work. Tried it in both IE and Firefox. If you resize it to less than 20KB, you can post it here. FWIW & HTH. . .
Registered Member Username: Sylverstone_pd4501864
Post Number: 255 Registered: 7-2005 Posted From: 216.173.223.253
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 8:14 pm: | |
this is the pic he's talking about: http://www.warbusaur.com/chuck/bypass.jpg -dd |
Post Number: 292 Registered: 11-2005 Posted From: 63.97.117.22
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 9:31 pm: | |
Chuck, From my memory I think your photo shows the water/air controller for the radiator shutters and contains some thermostats. Is definitely not the air gov because you can see it is in the water system. The original air comp gov is high on the right side (Pass) mounted on the firewall and will have a small air line to the compressor. Or; it may have been converted to the new type mounted on the comp head. I changed mine on my 4104 to the new type but kept it on the firewall. Had to use a few different adapters for the air connections but figure it takes a lot less abuse and heat away from the comp. |
Post Number: 293 Registered: 11-2005 Posted From: 63.97.117.22
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 9:33 pm: | |
Chuck, Forgot to mention, the new type looks nothing like either of the two original types. I, too, went crazy trying to find the one shown in the manual. |
Post Number: 18 Registered: 1-2007 Posted From: 64.12.116.138
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 23, 2007 - 10:44 pm: | |
Thanks Gus..... You have named the mystery part! Darn, I was hopeing it was the part I was looking for. At least I didn't have anyone pull it off for a rebuild. Regards, Chuck |
Post Number: 296 Registered: 11-2005 Posted From: 63.97.117.17
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 27, 2007 - 12:23 am: | |
Chuck, Did you ever find the governor? |
