Darren Upfield (Mwerx)
Registered Member Username: Mwerx
Post Number: 33 Registered: 6-2006 Posted From: 69.19.14.37
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 31, 2007 - 10:40 am: | |
trying to find weight & hight for shell no a/c heat,seats ??? Thanks Darren. |
Bob greenwood (Bob_greenwood)
Post Number: 623 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 31, 2007 - 10:55 am: | |
this might help a little.. I took 2000 pounds of seats out & the A/c would be about 500 pounds |
Ron Walker (Prevost82)
Post Number: 261 Registered: 11-2003 Posted From: 69.10.145.151
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 31, 2007 - 4:01 pm: | |
The weight on my gutted shell was around 26,000 lbs and the height was 11'-6" |
Muddog16 (Muddog16)
Registered Member Username: Muddog16
Post Number: 314 Registered: 11-2004 Posted From: 4.224.243.206
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 31, 2007 - 4:56 pm: | |
My 82 LeMirage weighed in about the same as Ron's, but my roof height accordingly to the name plate was 11'3" before the 9" roof raise! |
Post Number: 34 Registered: 6-2006 Posted From: 66.82.9.90
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 31, 2007 - 7:57 pm: | |
Thanks all, where does all the weight come from?? my buddys western star truck with a condo sleeper is lighter.Darren |
Muddog16 (Muddog16)
Post Number: 315 Registered: 11-2004 Posted From: 4.224.225.125
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 31, 2007 - 8:26 pm: | |
Well Darren the engine and trans weigh about 3,000 lbs, have you seen the chassis structure around the drive and tag wheels that is some heavy steel, the front end is the same, well made and of course heavy! A tire and wheel are around 250 lbs, you keep adding all of the systems in there and it doesn't take much to add up! I'd venture a guess that the drive axle assembly alone weigh around 3,000 lbs! Pat (Message edited by muddog16 on January 31, 2007) |
Post Number: 22 Registered: 10-2004 Posted From: 24.62.105.169
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 31, 2007 - 8:27 pm: | |
Holy Bleep Batman, My crown weights 26k gutted and your coach is twice as big. |
James Stacy (Jimstacy)
Post Number: 27 Registered: 1-2001 Posted From: 69.151.172.85
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 01, 2007 - 9:08 am: | |
My aluminum 4104 (6V92/V730, oak interior, cultured marble) fuel and water tanks full & all our toys for a Winter of traveling weighed 27,000 fully loaded. It ain't just the drive train that's heavy. |
Post Number: 28 Registered: 1-2001 Posted From: 68.89.22.181
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 02, 2007 - 11:49 am: | |
Obviously, 5' more of bus length and a tag axle would add quite a bit of weight to the '04 but the aluminum buses are thousands of pounds lighter than the steel units. The 4106 is many hundreds of pounds lighter than the '04 even though it has a heavier engine. They made the '06 skin thinner than on the '04 when they found the '04 was over built. FWIW Jim Stacy |
Gary Langley (Glang)
Registered Member Username: Glang
Post Number: 10 Registered: 1-2001 Posted From: 71.3.228.85
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 03, 2007 - 4:26 pm: | |
My 80 Prevost loaded for the road 6'Roof raise ,8V92-740 weighs 35,900lbs |
Post Number: 634 Registered: 7-2006 Posted From: 64.136.49.228
Rating: Votes: 1 (Vote!) | Posted on Saturday, February 03, 2007 - 5:06 pm: | |
I just took a picture of my bus &just the picture weighs 6 pounds |
