Air gauge problems Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » February 2007 » Air gauge problems « Previous Next »
Dennis Tracy (Eagle10)
Username: Eagle10
Post Number: 5
Posted From: 70.127.53.11
Posted on Monday, February 12, 2007 - 12:30 pm:
I have a 1984 Eagle 10 and the front and rear air gauges started to stop working at any moment. They gauges won't work at all and all of a sudden they will work properly. When they don't work, the fuel gauge reads incorrectly. Sometimes when I turn the bus off and on again everything works O.K. {sometimes it does not] I have cleaned the fuses but no luck so far. Any ideas would be great. Thanks.
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 673
Posted From: 64.136.49.228
Posted on Monday, February 12, 2007 - 1:39 pm:
GROUND WIRE.....OR.....ignition switch
(Message edited by bob greenwood on February 12, 2007)
Username: George_mc6
Post Number: 86
Posted From: 207.231.81.154
Posted on Monday, February 12, 2007 - 2:35 pm:
Wiggle wires, (no joke) from the gauges to the pressure sending units, and on the dash ground to the frame. ONE WILL BE LOOSE. I'm going to make a LARGE bet on Bob's first two words, just adding one word in front, to make it read LOOSE GROUND WIRE!!! The funny fuel gauge is the clue. (They all have to be grounded, and when not, one tries to back up through the other...)
Username: Eagle10
Post Number: 6
Posted on Monday, February 12, 2007 - 4:57 pm:
I was hunting for the ground wires and have wiggled many wires but have not found the correct one yet. I pulled the dash and pulled on those wires with no result. Anyone know where I would find the sending units for these gauges? Keep the ideas coming. Thannks.
Post Number: 677
Posted on Monday, February 12, 2007 - 6:07 pm:
sending units ain't the problem
Post Number: 87
Posted on Tuesday, February 13, 2007 - 12:27 am:
Bob's right again, you've got a high resistance ground somewhere. Find the dash ground wire to the frame, and take off the nuts holding it on the stud. Clean the terminals, and retighten. All the gauges have to ground properly to work, and as soon as you mentioned the fuel gauge not working properly at the same time, this is a dead giveaway of an open-high resistance-or intermittent ground. Otherwise the fuel gauge wouldn't act funny, and why would both air gauges go wrong at the same time?
HTH, George
Muddog16 (Muddog16)
Username: Muddog16
Post Number: 324
Posted From: 4.224.204.108
Posted on Tuesday, February 13, 2007 - 6:47 am:
Check main chassis gnd connection at the battery connection also in your control panel check the grounds there! IF you have to take the main ground wire loose at each connection and clean them up and retighten them!
Pat
Username: Eagle10
Post Number: 7
Posted on Tuesday, February 13, 2007 - 7:41 pm:
Thanks for the ideas. I will start hunting down ground wires and connections. I will let you know the results.
