Which block heater?? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » February 2007 » Which block heater?? « Previous Next »
Cameron Jones (Crazy71)
Username: Crazy71
Post Number: 22
Posted From: 75.179.153.89
Posted on Sunday, February 18, 2007 - 8:11 pm:
I have decided to get a block heater. I have a 8v71 in a MC8.
Apparantly there are two types....One is a screw in near the starter...the other is a 4 bolt plate style that says for right side...
Is there any advantage to one or the other?
I assume they both heat the coolant in the block. Right??
I just want the easiest one to install I guess.
Thanks
Chuck Lott (Chuckmc8)
Username: Chuckmc8
Post Number: 206
Posted From: 74.224.206.164
Posted on Sunday, February 18, 2007 - 9:20 pm:
Cameron,You have to drain the coolant to install either one. The 4 bolt plate is the easiest to install and the one most commonly used. Mine works great.....easily one of the best returns on $$$ and time on bus project- HTH
Laryn Christley (Barn_owl)
Username: Barn_owl
Post Number: 2
Posted From: 71.254.45.168
Posted on Sunday, February 18, 2007 - 11:27 pm:
The 4 bolt is the easiest but I had to use the screw in because my transmission cooler used that access hole. The 4 bolt is a 1500w unit, the screw in types come in 1000w and 1500w. I couldn’t get the 1500W to fit because of clearance issues that my transverse configuration creates in my GM. I really wanted to use the 1500w but I have found that I have had no problems with the 1000w unit. Some of the best money I ever spent, well worth it. Quick starts and it’s better for the engine. The 1500w sells for around $42 and the 1000W for $40 at a local truck parts supplier.
Username: Crazy71
Post Number: 23
Posted on Monday, February 19, 2007 - 1:46 am:
It seems the 4 bolt plate one is most common.
I guess this is the one that goes in on the right side near starter (MCI 8)
i found another one that is a screw in...It says it goes in the front face on engine...
http://www.kimhotstart.com/kimhotstart/uploads/documents/catalog/imc_500_section_6.pdf
It is AC-101 on this link. Is this the same screw in one you are talking about?....If so where does this screw into?
Thanks again.
Dale Waller (Happycampersrus)
Username: Happycampersrus
Post Number: 304
Posted From: 69.19.14.37
Posted on Monday, February 19, 2007 - 7:27 am:
"Is this the same screw in one you are talking about?....If so where does this screw into?"
Yes, that's the one. It screws into a plug that has to be removed from the block, right below the head in the block water jacket. These plugs can be a pain to remove.
HTH,
Dale
Username: Chessie4905
Post Number: 427
Posted From: 71.58.126.56
Posted on Monday, February 19, 2007 - 7:52 am:
If you decide you want to use the screw in type, try breaking the plug loose before you order the heater in case the plug doesn't want to budge.
Username: Barn_owl
Post Number: 3
Posted on Monday, February 19, 2007 - 9:59 am:
To remove my plug I had to drain the coolant and use a torch to get the plug very hot (The fleet mechanics where I worked told me how to do it). I did try first without the heat, and a very long cheater bar, but no luck. After adding the heat it came out with a short breaker bar, no problem. Probably could have used just a ratchet.
Username: Crazy71
Post Number: 24
Posted on Monday, February 19, 2007 - 6:07 pm:
Thanks for the info..I have read the plugs can really be IN there. I will try to break it free first. Looks like it would be a bit easier to install than the plate one if it will budge.
