WILLIAM D. WATKINS (Sivrtnge2)
Registered Member Username: Sivrtnge2
Post Number: 34 Registered: 11-2006 Posted From: 76.97.120.244
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 20, 2007 - 9:51 pm: | |
I am trying to find the best way to route the 50 amp cord from the second foward driver side bay to the back of my Eagle at the tag on the driver side. can someone show me some pictures or give me some pointers. There is a channel underneith the coach on the driver side, but i need to know how and if this area will work!!! -- BILL |
Bob greenwood (Bob_greenwood)
Post Number: 714 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 20, 2007 - 10:13 pm: | |
I don't understand why...you are supposed to have a main fuse & disconnect box where service enters the coach,then, I ran elec. up,thru the floor to a converter,that had breakers & the 12/2 with ground was distributed throughout the coach,can't imagine why you would want to run it back there,but,the tunnel might be a posibility |
Post Number: 214 Registered: 7-2006 Posted From: 66.217.108.110
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 21, 2007 - 10:35 am: | |
"the back of my Eagle at the tag on the driver side" Through the years, we've stayed at more campgrounds that didn't "conform" to the usual layout you'd expect to find.... I.E.: The power pole is not always where you would expect to find it. At many of the county, state, and private campgrounds, the power pole was at the rear, side, or front, and even on the passenger side (if you backed in)... You may be better off, simply having the cord out the mid-side, rather than the rear. (at least, that's what I had planned) Then, you'd have a better chance of reaching the PP with a standard 30' shore-line. |
Post Number: 87 Registered: 12-2000 Posted From: 71.31.109.11
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 21, 2007 - 10:47 am: | |
Just because I'm a code freak NEC Article 551-46(e) Location. The point of entrance of a power-supply assembly shall be located within 15 feet of the rear, on the left (road) side or at the rear, left of the longtitudinal center of the vehicle, within 18 inches of the outside wall. Len (Message edited by lsilva on February 21, 2007) |
Post Number: 216 Registered: 7-2006 Posted From: 66.217.108.110
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 21, 2007 - 12:00 pm: | |
And because I'm just a freak: "shall be located within 15 feet of the rear" On a 40' coach, that's damn near mid-point, ehh? (jeeesh) |
