Cameron Jones (Crazy71)
Registered Member Username: Crazy71
Post Number: 25 Registered: 12-2006 Posted From: 75.179.153.89
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 3:09 am: | |
I can't find any straight 40 around southwest ohio area. Napa can order their brand that says less than 1% ash but I would much rather have a brand name. I really want to find Delo 100. I hear it has the best specs. I tried the Chevron website lookup and made a phone call or two but came up with nothing promising. |
Bob greenwood (Bob_greenwood)
Post Number: 723 Registered: 7-2006 Posted From: 64.136.26.226
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 5:04 am: | |
look in the phone book..chevron,under oil distributors Ohio lube..937-667-6211 B.P. 937-222-4571 Am. Lube 937-222-2851 (Message edited by bob greenwood on February 22, 2007) |
Douglas Wotring (Tekebird)
Post Number: 114 Registered: 10-2004 Posted From: 71.59.75.212
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 9:11 am: | |
NAPA can order Chevron 40 wt as well.......I am getting more and more disapointed in NAPA Employees....seems it is hard to find one that is willing to do a parts guy's job anymore.....looking things up. I get mine from the distributor, almost 2.00 cheaper than NAPA......and if I get 6 cases they deliver it from 60 miles away for free. |
Austin Davis (Zimtok)
Post Number: 94 Registered: 9-2006 Posted From: 216.37.73.226
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 10:50 am: | |
I think TSC (Tractor Supply Store) has straight 30 and 40 for diesel engines. (don't remember what brand name) I've seen it there in 5 gal buckets for around $45. . |
Ross Carlisle (Rrc62)
Registered Member Username: Rrc62
Post Number: 171 Registered: 5-2005 Posted From: 67.142.130.31
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 10:59 am: | |
NAPA can also order Rotella-T. I've found a few that stock it, but not many. The NAPA in where I used to live in NH stocked it because I was using it and I asked them to stock it. Ross |
Post Number: 429 Registered: 10-2003 Posted From: 71.58.126.56
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 12:47 pm: | |
I purchased a 55 gallon drum from local fuel and oil distributor. Should last for a few years and looks like 40wt is going to be more difficult to locate in some areas as time goes on. |
Mark Renner (Boomer)
Post Number: 42 Registered: 11-2006 Posted From: 12.180.53.193
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 12:54 pm: | |
Don't know about the midwest, but in the west Costco carries Delo 400/40 in 1 gallon by the case at an attractive price. Might check at Walmart too. |
E. R. Red Ruby (Beatsworkin)
Registered Member Username: Beatsworkin
Post Number: 14 Registered: 2-2006 Posted From: 69.222.22.75
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 2:08 pm: | |
phillips 66 super duty 40 is good also Red |
J.C.B. (Eagle)
Registered Member Username: Eagle
Post Number: 101 Registered: 12-2000 Posted From: 74.130.42.250
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 2:15 pm: | |
TSC Tractor Supply's oil does not meet required specs for a DD two stroke |
Post Number: 1195 Registered: 12-2000 Posted From: 71.195.112.181
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 2:37 pm: | |
Mark - Delo 400 is no longer listed by Chevron as a CF-2 oil, it's been reformulated for the four-strokes, now carries a CF-4 rating. Check the labels closely, as there is some older production 400 rated CF-2 floating around out there. FWIW & HTH. . .
Post Number: 729 Registered: 7-2006 Posted From: 64.136.27.229
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 3:30 pm: | |
AHHHHHHHHH...RotellaT |
Post Number: 430 Registered: 10-2003 Posted From: 71.58.126.56
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 7:36 pm: | |
When Mobil combined with Exxon they replaced Delvac 1100 40W with Exxon XD3 with same specs.( meets CF2 and CF ) |
Post Number: 305 Registered: 11-2005 Posted From: 206.40.238.32
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 22, 2007 - 10:51 pm: | |
Believe it or not Rotella-T is available at Home Depot!! If your local HD doesn't have it ask them to order it for you. I found mine in a MS HD probably because there is a lot of logging there. Any place near marine or logging industries will have it. |
Ednj (Ednj)
Post Number: 140 Registered: 3-2003 Posted From: 67.85.229.237
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 23, 2007 - 12:36 am: | |
I sent Shell Rotella ask or expert an e-mail asking about their oil in a 2 stroke 8v71, here is their answer. Ed, Shell Rotella T Single Grade SAE 40 is acceptable for Detroit Diesel series 71 2-stroke engines in the vast majority of applications. The exceptions would be for ambient temperatures below 0 deg F (SAE 15W-40 acceptable, SAE 30 OK in non-marine applications) or when coolant outlet temperatures exceed 200 deg F (SAE 50 recommended). Higher TBN oils may also be acceptable where the fuel sulfur level exceed 0.5%. Regards, XX XXXXXXX Subject: Rotella Ask Our Expert: Vehicle-Related |
Dennis_johnson (Dennis_johnson)
Registered Member Username: Dennis_johnson
Post Number: 4 Registered: 4-2006 Posted From: 66.82.9.87
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 23, 2007 - 10:28 am: | |
Cameron, I am not sure where you are in SW Ohio, but I have been buying 40 wt. Rotella from the NAPA in Miamisburg. They usually have it, but if not will order it and have it in a couple of days. |
Fred MacIsaac (Bassfid)
Registered Member Username: Bassfid
Post Number: 1 Registered: 2-2007 Posted From: 24.99.70.219
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 11, 2007 - 8:53 pm: | |
O'Reilly Auto Parts has (or can order) delo 100 40w. I got some last week in the Atlanta,GA area for about $9 a Gallon. They were able to get it the next day. (Message edited by bassfid on March 11, 2007) (Message edited by bassfid on March 11, 2007) |
Jim Rink (Fakeguy)
Registered Member Username: Fakeguy
Post Number: 25 Registered: 1-2005 Posted From: 24.33.85.105
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 31, 2007 - 9:07 pm: | |
I live in Milford, OH, just east of Cincinnati. Tractor Supply (TSC) has straight 30 and 40 in 5 gal and 2 gallon containers. They have stores in Fairfield, Batavia and Loveland that I know of. Just changed mine last weekemd in my PD4106 with 8V71 Detroit Diesel on Kemper Rd in Cincinnati and Truck Pro have filters. Dietoit Diesel has conversion kit (about $40) for spin on filter and original filter replacements. email me outside if you need more info. just click on my name next to posting |
Jim Rink (Fakeguy)
Post Number: 26 Registered: 1-2005 Posted From: 24.33.85.105
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 31, 2007 - 9:16 pm: | |
OH...I should have read all the postings sooner...I just saw JCB EAGLES posting TSC Tractor Supply's oil does not meet required specs for a DD two stroke |
clark lane (Bus05eagle)
Registered Member Username: Bus05eagle
Post Number: 1 Registered: 3-2007 Posted From: 74.33.45.29
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 31, 2007 - 9:46 pm: | |
Jim, if you have a DD dealer in your area you can buy the right oil from them and it doesn't cost any more than other places |
