Tim Jones (Torquester)
Registered Member Username: Torquester
Post Number: 104 Registered: 12-2000 Posted From: 71.218.187.57
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 27, 2007 - 10:39 pm: | |
Hi all, I need to buy a new truck and I want to make sure that I can tow it 4-down. I have been searching around for a list that I know is out there but I can't find it. I am no longer a member of FMCA. I prefer GM products. Does anybody know of a free listing of models that might fit my requirements? 4X4, auto tranny, no tranny pump or driveshaft disconnect. TIA, Tq (Message edited by torquester on February 27, 2007) |
Duane Bratvold (Connieandduane)
Registered Member Username: Connieandduane
Post Number: 38 Registered: 10-2006 Posted From: 205.242.83.12
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 28, 2007 - 10:14 am: | |
The Dodge Dakota extended cab 4x4 works fine. It has a disconect button to put everything in nuetral. My father in law has been towing one for years and has had good luck with it. |
J.C.B. (Eagle)
Registered Member Username: Eagle
Post Number: 103 Registered: 12-2000 Posted From: 74.130.42.250
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 28, 2007 - 10:21 am: | |
Tim I sent you an E-Mail with FMCA's list of towables for 2007. |
Ednj (Ednj)
Post Number: 141 Registered: 3-2003 Posted From: 67.85.229.237
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 28, 2007 - 11:02 am: | |
Try this one = http://www.motorhomemagazine.com/dinghytowingguide/index.cfm > Good luck |
Arnie Molloy (Ayjay)
Registered Member Username: Ayjay
Post Number: 67 Registered: 10-2005 Posted From: 151.203.210.131
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 28, 2007 - 11:23 am: | |
Hi: Try "towing world.com". the listing is current thru 2006, I don't believe the 2007 listing has been released as yet |
Evan G. (Fireman10b)
Registered Member Username: Fireman10b
Post Number: 12 Registered: 5-2005 Posted From: 209.183.174.10
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 28, 2007 - 11:42 am: | |
Check out this web site I think it will help. I use this on a 2004 Chevy pickup. http://www.remcotowing.com/drive.asp |
Post Number: 105 Registered: 12-2000 Posted From: 205.169.164.69
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 28, 2007 - 1:20 pm: | |
Thanks y'all. It's good to have friends here. Tq |
Post Number: 444 Registered: 10-2003 Posted From: 71.58.126.56
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 28, 2007 - 6:12 pm: | |
BTW, Dodge isn't owned by GM yet. |
Registered Member Username: Muziklvr
Post Number: 66 Registered: 7-2006 Posted From: 71.228.195.103
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 28, 2007 - 10:11 pm: | |
does anyone know if you can can tow a 01 ford expedition (2wd) with all four wheels down without any modifications or not????? |
Post Number: 448 Registered: 10-2003 Posted From: 71.58.126.56
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 01, 2007 - 10:31 pm: | |
If it is an automatic, you will have to disconnect the driveshaft, as the rear clutch/bushing, and bearings will not receive proper lubrication unless the engine is running, or there is a lube pump installed to provide the lubrication when the engine is off. |
Ross Carlisle (Rrc62)
Registered Member Username: Rrc62
Post Number: 173 Registered: 5-2005 Posted From: 67.142.130.37
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 02, 2007 - 9:26 am: | |
I've just been informed that all 4WD GM trucks to present are towable. I'll be shopping for a 1/2 ton extended cab soon. Ross |
Post Number: 453 Registered: 10-2003 Posted From: 71.58.126.56
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 02, 2007 - 7:49 pm: | |
From what year on? My 96 Jimmy isn't because it has push button 4wd, which doesn't provide a neutral position for towing. |
Post Number: 106 Registered: 12-2000 Posted From: 71.218.187.57
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 03, 2007 - 12:28 am: | |
John, I think in your owners manual you will find a way to shift into neutral. It's something like pressing the 2 wheel and the 4 low switch at the same time and holding them down for 10 seconds. hth, Tq p.s. I bought my new towed today..... 2007 GMC Sierra extended cab 4X4 (Message edited by torquester on March 03, 2007) |
Post Number: 1852 Registered: 1-2001 Posted From: 75.108.79.35
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 03, 2007 - 10:26 am: | |
John, here are the shifting instructions for my 99 Tahoe. Should be similiar to yours: 1999 Tahoe 4 X4 Shifting Transfer Case with automatic transmission and Electronic transfer case Shifting to Neutral The vehicle should be attached to the tow vehicle before shifting to neutral 1. Set the Parking Brake 2. Start the vehicle 3. Put the transmission in NEUTRAL (N) 4. Shift the transfer case to 2HI (if necessary) 5. Simultaneously press and hold the 2HI and 4LO buttons for 10 seconds. The NEUTRAL light will come on when the transfer case shift to neutral is complete. 6. Shift the transmission to REVERSE (R) for one second. 7. Shift the transmission to AUTOMATIC OVERDRIVE (D) for one second. 8. Turn the ignition switch to OFF (Accessory, not lock) 9. Place the transmission shift lever in PARK (P) 10. Release Parking brake 11. Make sure steering wheel is not locked. Shifting out of Neutral 1. Set the parking brake 2. Apply the foot brake 3. Start the vehicle with the transmission in PARK (P) 4. Press the 2HI button 5. Shift the transmission to NEUTRAL (N) 6. When the transfer case has shifted out of NEUTRAL the NEUTRAL light will go out and the 2HI light will come on. Reference pages 2-24 and 4-22, 1999 Tahoe/Suburban owners manual Richard |
Post Number: 454 Registered: 10-2003 Posted From: 71.58.126.56
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 03, 2007 - 10:27 am: | |
Thank's, I'll check that out and get back to you on it. |
Post Number: 456 Registered: 10-2003 Posted From: 71.58.126.56
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 03, 2007 - 11:26 am: | |
Just checked owner's manual;" Towing behind a motorhome with push button transfer case is not recommended because transfer case does not have a neutral position." Oh, well, I was hoping that mine was one of the ones you could do that with. |
