Registered Member Username: Texasborderdude
Post Number: 5 Registered: 3-2007 Posted From: 75.50.236.89
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 06, 2007 - 2:05 pm: | |
My '78 Eagle Model 05 lube guide specifies Type A Suffix A ATF for the power steering. I can't find such a beast but it seems that Dexron (III) is the successor. Is this the correct fluid? |
Jerome Dusenberry (Jerry32)
Registered Member Username: Jerry32
Post Number: 8 Registered: 1-2007 Posted From: 148.78.243.52
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 06, 2007 - 2:18 pm: | |
Yes type "A" was GM and type "F" was Ford. then came dexron replacing type "A". |
Post Number: 6 Registered: 3-2007 Posted From: 75.50.236.89
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 06, 2007 - 2:33 pm: | |
Thanks! This board (and it's members) is (are) amazing! |
Post Number: 310 Registered: 11-2005 Posted From: 63.97.117.26
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 06, 2007 - 11:57 pm: | |
Doyle, That is the way I see it also. All I can remember is type "A" and "F" and I know F is for Ford so I use DexIII in my 4104 original power assist steering. |
Hans (Buellhans)
Registered Member Username: Buellhans
Post Number: 29 Registered: 2-2007 Posted From: 199.60.181.9
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 07, 2007 - 9:50 am: | |
Hey you sould try the transynd from DDA stuff is amazing , cooler trans temps less intervails for changes . Price is alittle scary but you get what you pay for . My trans shifts better as well ,30 to 40 degrees cooler on the temp gauge . Try it youll like it (Message edited by buellhans on March 07, 2007) |
Post Number: 311 Registered: 11-2005 Posted From: 63.97.117.40
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 08, 2007 - 12:06 am: | |
Hans, This is for his power steering not his trans! |
Hans (Buellhans)
Post Number: 33 Registered: 2-2007 Posted From: 205.250.41.167
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 14, 2007 - 12:41 am: | |
Really we run it in all our buss trans I must tell them the error of there ways and yes you can run it in the power steering and fan drives as well . |
