Dutch with the gm4106 made it home Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » March 2007 » Dutch with the gm4106 made it home « Previous Next »
dutch (Dutch)
Username: Dutch
Post Number: 21
Posted From: 216.9.250.6
Posted on Friday, March 16, 2007 - 12:21 am:
Oo yes!!!!!!
1350 miles with a tiny issue with the gascable.
Now my questions.
The original speedometer does not work ...how diicficult is it to fix???
For my next trip....what service should I do to it???
The toilet its the original...does it have a holdingtank or does it drain straight outv??
Also where do I get new wheelsimulators
And what recommended tools do I absolutely need to carry with me.
Thanks dutch
norcal kyle (Kylexisxrad)
Username: Kylexisxrad
Post Number: 131
Posted From: 216.220.208.126
Posted on Friday, March 16, 2007 - 12:43 am:
congrats on the trip! a fairly uneventful trip is a success in my book. for service, if you haven't had the fluids changed(oil, coolant, etc), do that asap. it will definetly help the ol' 318 out quite a bit. for the speedo, I'd try luke @ US Coach. he can help pretty much anyone, and his service is top top top notch. for simulators, I'd check w/ Hub King, or on ebay for good deals. or post a want ad in the bno flea market and maybe someone can help. for parts, I'd definetly have a full set of filters ready in the bay, because chances are truck stops WILL NOT have two stroke style filters, only the DD dealers. it could be a lifesaver. its not much, but hope it helps. again, CONGRATS ON THE SUCCESS!!!!!!!
kyle in norcal
Don Evans (Doninwa)
Username: Doninwa
Post Number: 21
Posted From: 65.61.96.82
Posted on Friday, March 16, 2007 - 2:08 am:
One of the most important things to have are the manuals for the coach. It will give you step by step instructions for permanently taking care of almost every system on/in the coach. Things like how to remove, inspect, clean, lube, install, and adjust the throttle cable:-)
Good luck with the new toy.
Don 4107-501
