Gmc 4106 not charging Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » March 2007 » Gmc 4106 not charging « Previous Next »
dutch (Dutch)
Username: Dutch
Post Number: 22
Posted From: 66.68.98.151
Posted on Friday, March 16, 2007 - 10:05 am:
hello fellow nuts
my generator of the main engine is not charging anymore(at least the dashboard display is telling me that.)
what can/should i do to fix/located the problem??
Username: Rjlong
Post Number: 1205
Posted From: 71.195.112.181
Posted on Friday, March 16, 2007 - 10:45 am:
Dutch -
On my 4106, the charging system doesn't kick in until there's at least 60 psi in the air system. Not sure why, since the alternator's gear driven. I think it had to do with the clutch mechanism for the A/C.
The OEM voltage regulator is on the rear wall of the rear baggage compartment.
There is a relay in the electrical compartment behind the RR wheel. Sometimes the contacts get a little dirty and they need to be cleaned. Use a "points file" - one of those little files we used to use to clean the points in a distributor back before electronic ignitions. Make sure you disconnect the batteries before doing this, or sparks will fly!!
FWIW & HTH. . .
