john montgomery (Johnjem)
Registered Member Username: Johnjem
Post Number: 10 Registered: 3-2007 Posted From: 24.34.214.231
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 18, 2007 - 6:21 pm: | |
my manual says on the right bank next to air box cover,is the #'s i cant get behind there to see##s and the pic does not have a starter in it so i cant even be sure where the #s are right bank left bank,am i looking at the front of the motor or the rear of the motor to determin if it is L/R bank all i got was a bunch of paint chips in the eye today any good hints? 1970 gmc 4905 8v71????? |
Post Number: 11 Registered: 3-2007 Posted From: 24.34.214.231
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 18, 2007 - 6:42 pm: | |
ps my starter is on the right side if i am faceing the motor and on the pass side of the bus??any cluesssss |
george bruton (Tazman632000)
Registered Member Username: Tazman632000
Post Number: 10 Registered: 2-2007 Posted From: 65.184.183.4
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 18, 2007 - 9:04 pm: | |
look on the side of the governer |
Mark Renner (Boomer)
Post Number: 48 Registered: 11-2006 Posted From: 12.180.53.193
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 18, 2007 - 11:35 pm: | |
Look at the flat machined surface at the left front of the block, between the cylinder head and the mounting location for the block heater (square cover plate with 4 bolts if block heater is not installed). |
evan (Legaleagle82)
Registered Member Username: Legaleagle82
Post Number: 5 Registered: 12-2006 Posted From: 69.245.4.209
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 19, 2007 - 1:27 am: | |
try this sight for some good info on the v71, http://www.powerlinecomponents.com/literature/detroit_diesel/v71_model_chart.htm should help you with number locations. Evan |
Post Number: 12 Registered: 3-2007 Posted From: 24.34.214.231
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 19, 2007 - 3:27 pm: | |
still no ##S dont know why??just cant find them |
Mike Eades (Mike4905)
Post Number: 146 Registered: 12-2000 Posted From: 68.207.200.143
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 20, 2007 - 9:18 pm: | |
John What numbers are looking for? If you looking for bus numbers, look in side you service door under drivers seat area on the frame. If you are looking engine numbers, the right side is looking from the right side of the bus or transmission side. Right is the high side near the bulk head. |
Post Number: 13 Registered: 3-2007 Posted From: 24.34.214.231
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 21, 2007 - 1:05 pm: | |
HEY MIKE! i am so new to these bus terms it is not funny i have scrathed all my hair out of my head!! lol yes i am looking for the engine# on my 8v71,my engine sits side ways,so these L/R ARE CONFUSING me <if>what side of the block am i to look for the ##s <the front of the motor or the rear remember i am looking at it with the fan 2 my left and the tranny to my right and the motor sits side ways , |
Don Fairchild (Don_fairchild)
Registered Member Username: Don_fairchild
Post Number: 1 Registered: 3-2007 Posted From: 66.17.9.74
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 22, 2007 - 11:51 am: | |
John; The numbers are on the right side if the engine when looking from the flywhell end. They will be just above the starter between and below the first and second air box covers on early model blocks, and on the pad at the front right of the block below the head on newer blocks. If the engine was rebuilt and a new block was installed they may not of restamped the numbers on it.( not uncommon ) If you need #'s to buy parts let me know and I can give you some #'s that will work. Hope this helps Don |
Post Number: 15 Registered: 3-2007 Posted From: 24.34.214.231
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 22, 2007 - 3:37 pm: | |
THANKS SO MUCH THAT HELP I GOT THE ##S RIGHT BEHIND THE STARTER<I WISH I KNEW THAT A WEEK AGO BUT I GOT IT THANKSSSSSSSS GUYS,!!!!! |
