Door air lock on 4106? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » March 2007 » Door air lock on 4106? « Previous Next »
Darrell Black, DVM (Darrelldvm)
Username: Darrelldvm
Post Number: 28
Posted From: 209.78.171.116
Posted on Sunday, March 18, 2007 - 8:48 pm:
Has anyone put the MCI air lock on a 4106 entrance door? How?
Laryn Christley (Barn_owl)
Username: Barn_owl
Post Number: 15
Posted From: 71.254.45.168
Posted on Sunday, March 18, 2007 - 9:24 pm:
Darrell,
I’m curious, why would you want to do that? Does it pull it in tighter? I don’t know much about the MCI’s or how an air lock works. What happens when you don’t have the bus aired up?
Username: Rjlong
Post Number: 1210
Posted From: 71.195.112.181
Posted on Sunday, March 18, 2007 - 10:25 pm:
Laryn -
The MCI air lock does, in fact, pull the heavy door in tighter to the body of the coach. (BTW, MCI doors are quite a bit heavier than a GMCs.)
The air lock only works when the ignition is on and the door is closed. It releases when the ignition is off.
Darrell -
I don't know anyone who's added one to a GMC, but have often thought it's not a bad idea. Don't know if there's enough clearance in the wheelwell for the mechanism, but, as creative as busnuts are, I'm sure it could be done.
FWIW & HTH. . .
