chris green (Milkshake)
Registered Member Username: Milkshake
Post Number: 1 Registered: 3-2007 Posted From: 72.153.102.48
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 25, 2007 - 6:40 pm: | |
My brakes siezed on my 1971 MCI MC-7. I had a service co. come out and look at it and he said that the AIR chamber thingy (big cylinder looking thing) popped and locked my rear right brakes and it needs to be rebuilt. I'm on a tour with a band and need help ASAP and need to be on the road no later than monday night. if you can help, Its much appreciated. please call me ASAP- 847-863-6499 |
Bob Wies (Ncbob)
Registered Member Username: Ncbob
Post Number: 205 Registered: 2-2006 Posted From: 66.174.93.100
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 25, 2007 - 7:06 pm: | |
Chris, try this... Wait until you have maximum air pressure (125#). Release the parking brake control. Hold the brake treadle down for a minimum of 5 seconds (stand on it) or longer. quick release..and attempt to move the bus. If this doesn't work cycle the parking brake knob to release and back on without your foot on the treadle...block the wheels for safety...and try again. What can happen is that the grease used to lubricate the balls for the locking portion of the parking brake can get hard and require a bit of extra effort to release them. Mine did ...and as soon as I could I rebuilt the DD-3's. Good Luck. NCbob |
Bob greenwood (Bob_greenwood)
Post Number: 780 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 25, 2007 - 11:17 pm: | |
NAAAAAAA....sounds like someyhig broke.....best I can tell you .....call LUKE......this is going to be a few days.....888-262-2434 somebody back me up on that number....I'm haveing eye problems |
larry currier (Larryc)
Post Number: 66 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 25, 2007 - 11:19 pm: | |
It might just be a stuck shoe. Put a little torque on it in reverse, see if it comes loose. Where are you? If the DD3 needs a rebuild then you need to rebuild or exchange it now. You may be able to run a maxi can if you can't find a DD3. Find a commercial brake rebuilder in your area. There are parts available next day air also. |
Post Number: 783 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 25, 2007 - 11:38 pm: | |
yep....since you don't know what broke,or how to fix it...you are pretty much in the hands of whoevere you choose....ask servco if they will rebuild it...or recomend someone that can... |
WILLIAM D. WATKINS (Sivrtnge2)
Registered Member Username: Sivrtnge2
Post Number: 44 Registered: 11-2006 Posted From: 68.243.196.42
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 26, 2007 - 8:47 am: | |
If it is the brake chamber, you can get a new one at NAPA for around 45.00. You should also have a key on the one on your coach. Build your coach up to max air pressure, release the brakes, stick the key in the slot and turn it 45 degrees. Then back that chamber off with an open end box end wrench. I think its a 5/8 or 9/16. I am here in Lakeland Fl. but I have no way to get to you. I am at Quadra getting new Levelers. |
Post Number: 102 Registered: 12-2000 Posted From: 71.30.241.107
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 26, 2007 - 9:32 am: | |
Tampa Spring Company 8820 N. Brooks Street Tampa, FL 33604 (813) 933-2805 No personal experience, very good reputation. Len |
Post Number: 720 Registered: 11-2004 Posted From: 72.91.107.56
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 26, 2007 - 3:44 pm: | |
Chris - sorry I've been out of town - since your in my back yard - but Len has given you a good company - I have had work done at Tampa Spring and Brake for years and they are good - they are at the corner of Busch blvd and Brooks less than a mile east of I-275 on the way to Busch Gardens - if you need a tow they can probably get you a better Price than just calling Stepp's - I can be reached on my cell at 813- two six seven five four eight six if you need anything else - Niles |
Jim Shepherd (Rv_safetyman)
Registered Member Username: Rv_safetyman
Post Number: 249 Registered: 1-2004 Posted From: 67.142.130.31
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 27, 2007 - 1:55 pm: | |
Just to clarify. Several folks have given answers as if this was a spring brake system. It should be a DD3 and I doubt that NAPA will have that part. Just to be sure I did a search at the NAPA online store and got several hits for spring brake chambers but not DD3. DD3 is not a common item in the HD industry. I believe it is only used on buses. Also, the fix of backing off the spring with the draw bolt will not work on a DD3 as far as I know. Sounds like the shop that has been recommended will be able to deal with the DD3 system. Obviously, Luke will have the parts and can probably get them to the closest location quickly. Jim Shepherd Evergreen, CO ’85 Eagle 10/Series 60/Eaton AutoShift 10 speed transmission Bus Project details: http://www.rvsafetysystems.com/busproject.htm |
David Dulmage (Daved)
Post Number: 162 Registered: 12-2003 Posted From: 142.46.199.30
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 27, 2007 - 3:31 pm: | |
MCI Parts will also be able to supply the DD3 chamber. Their rebuilt chambers are in the range of $400.00 exchange (i.e. there is about a $400.00 core charge added that is refunded when the old chamber is received by MCI Parts). They should be able to send it to you overnight by courier. Go to the MCI website for contact information. You will need to call by telephone. They are not usually very responsive to e-mails. HTH Dave Dulmage |
Post Number: 787 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 27, 2007 - 4:11 pm: | |
IF....you take the rubber diaphram out....and take it to a truck suppy...AND ...you DON't say nuthin'...about dd3....they have the diaphram |
