doug yes (Dougg)
Post Number: 14 Registered: 1-2007 Posted From: 4.235.249.198
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 29, 2007 - 6:57 pm: | |
We'are about to install the Fuel Pro 382 filter and replace a few lines while we're at it. Is any location OK? (I found a great spot on the left side at about chest height, which would entail running the fuel line on the ceiling of the engine compartment.) And is regular teflon tape OK for fuel lines? |
Mark Renner (Boomer)
Post Number: 53 Registered: 11-2006 Posted From: 12.180.53.193
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 29, 2007 - 7:43 pm: | |
Do not use tape or thread sealant on fuel lines. Hope you are using AeroQuip fuel lines and not rubber! |
Dan West (Utahclaimjumper)
Post Number: 33 Registered: 1-2005 Posted From: 208.66.39.51
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 29, 2007 - 8:29 pm: | |
You should READ the instructions for mounting, I believe they advise a particular hight in relation to the engine.>>>Dan |
Post Number: 333 Registered: 11-2005 Posted From: 63.97.117.40
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 30, 2007 - 12:33 am: | |
Doug, If you have an older GM bus with a pump on the engine almost any reasonably good rubber hose is ok because it is a suction system and not much suction at that. Since you don't tell us your bus type this may not apply. Use paste teflon sealant on threaded (NPT)fittings but not on tapered flare or compression fittings, this stuff is great. Teflon tape will shed small pieces and foul the fuel system. |
Muddog16 (Muddog16)
Registered Member Username: Muddog16
Post Number: 337 Registered: 11-2004 Posted From: 66.82.9.75
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 30, 2007 - 8:06 am: | |
Does anyone recommend a great supplier for the 382? |
doug yes (Dougg)
Post Number: 15 Registered: 1-2007 Posted From: 4.235.253.82
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 30, 2007 - 4:50 pm: | |
The best price we found was at Freightliner dealers. There are some cheaper on E-bay though. |
