Ammeter ticking Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » May 2007 » Ammeter ticking « Previous Next »
Steve Krane (Steve_krane)
Username: Steve_krane
Post Number: 18
Posted From: 76.176.33.74
Posted on Thursday, May 03, 2007 - 9:05 am:
Running down the road, my ammeter never registers more than about 10 amps. When things get to steady-state after an hour or so, the ammeter and voltmeter "tick", about once per second. Amps go 0-10-0 and Volts go 14.0 - 13.5 - 0. This goes on forever at about 1 cycle per second with more time at the 0 amps than the 10 amps.
Is that normal?
Edward J. Sommers (Sommersed)
Username: Sommersed
Post Number: 25
Posted From: 148.78.245.13
Posted on Thursday, May 03, 2007 - 11:59 am:
Sure, just shows that your regulator is working' If your batt was way down for some reason it would indicate a higher charging rate. Once your batt is full, and you have no other draw on them, like headlights, it should indicate 0 amps because you have no need for them, so none is produced, the bucket is full!
Username: Lsilva
Post Number: 110
Posted From: 151.213.164.91
Posted on Thursday, May 03, 2007 - 2:24 pm:
That's one of the things that happens when you have the big alternator on the bus without the normal bus load from the bus ac/heat.
I'll bet you would notice a difference in the timing of the "ticks" if you have all the lights on or whatever other load you can add to the bus elec system
Len
