Bob Symonds (Bob_symonds)
Registered Member Username: Bob_symonds
Post Number: 12 Registered: 5-2006 Posted From: 146.235.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 03, 2007 - 4:38 pm: | |
I am just looking for a picture. I have a spare governor, they both have different length "arms" that the throttle cable hooks to, I need to find out which is the correct one. |
Austin Scott Davis (Zimtok)
Post Number: 112 Registered: 9-2006 Posted From: 216.37.73.226
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 04, 2007 - 9:05 am: | |
Here is a photo of my Guv-na... 1960 4104 (Message edited by zimtok on May 04, 2007) |
Post Number: 13 Registered: 5-2006 Posted From: 146.235.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 04, 2007 - 4:24 pm: | |
wow... mine looks way different. My bus is a 1960 also... shouldn't the governors be the same? |
Post Number: 347 Registered: 11-2005 Posted From: 66.81.144.41
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 04, 2007 - 5:59 pm: | |
Bob, That looks pretty much like my '54 the best I can tell from the pic. |
Post Number: 14 Registered: 5-2006 Posted From: 146.235.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 04, 2007 - 7:33 pm: | |
looking at the pic straight on from the back - I have a set screw with a lock nut facing straight back on the lower left. On the right side I have a cover over another set screw, not that cylinder type thing shown in the pic, on the left I do not have whatever that air valve is, I also have a vent pipe were a screw on cover is shown in the pic heading out the back and going down to vent below the motor. Weird huh.... |
Post Number: 15 Registered: 5-2006 Posted From: 146.235.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 04, 2007 - 9:10 pm: | |
Well. There are 2 different governors used on these engines. The one shown in the pic on this post is a "fuel modulating governor"... mine is a "limiting speed governor". It shows in the manual but I did not recognize the difference before. Hopefully now I can get it setup correct. Thanks to all who helped. |
Mel La Plante (Mel_4104)
Post Number: 31 Registered: 7-2006 Posted From: 208.181.100.26
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 05, 2007 - 10:00 am: | |
Bob. you might want to get the help of a GOOD dd guy to set that up proper as it is not as simple as taking the cover off and turning nuts and screws. have you ever been close to a 6-71 when the gov. lets go into no high rpm control. man even when the parts come out side it still screams. this is why i say get some one that know what he is doing when working with your gov. and if you want to try it your self be sure that you have some way to shut it down in a hurry and do not use the emergence shut down as it will pull the seals out of the blower although it will be better that loosing the complete engine. |
Post Number: 16 Registered: 5-2006 Posted From: 64.252.176.46
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 05, 2007 - 5:26 pm: | |
I had it to 2 shops, both charged me but did not set it up correctly. Today I had a DD mechanic set it up correctly. He took parts from both governors to make one that was correct. This guy has been doing these motors for 35 years and knows them inside and out. He found a lot of little problems that he fixed. The bus runs much better now, My top speed is about 73. It handles hills better than before and I am able to cruise in the mid sixties and take the hills in New England much better. It took about 3 hours to go thru everything and cost me 150 bucks. Well worth it in my book. Thanks for all your help..... Bob |
Post Number: 1083 Registered: 5-2001 Posted From: 65.74.65.197
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 05, 2007 - 9:16 pm: | |
Glad you were able to get a good guy for that job, Bob. Tom Caffrey PD4106-2576 Suncatcher Ketchikan, Alaska |
Post Number: 167 Registered: 10-2004 Posted From: 71.125.9.71
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 05, 2007 - 9:58 pm: | |
Bob, your profile says you have a mc5c also. How do the 2 buses compare running maintenance wise etc? thanks Dave |
Post Number: 348 Registered: 11-2005 Posted From: 66.81.144.94
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 06, 2007 - 12:17 am: | |
Bob, Thatwas $150 well spent. I hope to do the same soon. |
Post Number: 32 Registered: 7-2006 Posted From: 208.181.100.49
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 06, 2007 - 12:21 pm: | |
Bob, it good to see that you went to a good DD guy that knew what he was doing, as you found out there are a lot of guys out there that will tell you that ya ya i know all about DDs and only know it runs on deisel and some have even used gas to try and start them. the gov. is the biggest thing on the engine that has been changed over the years and the most damage is done to them when not set up proper. out by my shop is a 6/71 block with a broken main cap and a broken block due to a Cat/cum. mec. that set it up and of course when it went bang he claimed it was a weak engine not the guy that did not know what he was doing. |
Post Number: 17 Registered: 5-2006 Posted From: 64.252.176.124
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 06, 2007 - 12:24 pm: | |
Dave - the MCI is a 6v71 with an automatic. It only has about 40,000 miles on it. It is much quicker than the GMC. Climbs a bit better, and tops out around 73 MPH. It has integral power steering and is real easy to drive. I haven't put a whole lot of miles on it. Wanna buy it.... The short of it is - I bought the GMC already converted after I had the MCI for 3 years. Life got in the way and I did not finish the MCI.... yet. |
