4104 ride height Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » May 2007 » 4104 ride height « Previous Next »
Bob Symonds (Bob_symonds)
Username: Bob_symonds
Post Number: 20
Posted From: 146.235.66.52
Posted on Tuesday, May 08, 2007 - 7:18 pm:
does the ride height make a difference in the ride. I think the PO set mine real high. I haven't taken the measurements yet but it does ride hard in the front. My air beams are still intact in the front.
Username: Chessie4905
Post Number: 547
Posted From: 71.58.117.21
Posted on Tuesday, May 08, 2007 - 7:58 pm:
Yes, it will ride rougher; as there is more air pressure in the bags, just like too much air in tires.Sometimes people set them high for more stability going down the road, also setting the air pressure in tires high for similar reasons. How mush air pressure in your front tires? Manual or power steering? What is your caster degrees? Sometimes people do the former to stop the wandering due to negative caster.
Username: Gusc
Post Number: 349
Posted From: 76.83.107.215
Posted on Wednesday, May 09, 2007 - 2:26 pm:
If you don't have radial tires in front the ride will be rougher also.
When I changed my 4104 to radials it made a huge difference even though the radial tire pressure was much higher.
