Bob Symonds (Bob_symonds)
Registered Member Username: Bob_symonds
Post Number: 20 Registered: 5-2006 Posted From: 146.235.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 08, 2007 - 7:18 pm: | |
does the ride height make a difference in the ride. I think the PO set mine real high. I haven't taken the measurements yet but it does ride hard in the front. My air beams are still intact in the front. |
Post Number: 547 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 08, 2007 - 7:58 pm: | |
Yes, it will ride rougher; as there is more air pressure in the bags, just like too much air in tires.Sometimes people set them high for more stability going down the road, also setting the air pressure in tires high for similar reasons. How mush air pressure in your front tires? Manual or power steering? What is your caster degrees? Sometimes people do the former to stop the wandering due to negative caster. |
Post Number: 349 Registered: 11-2005 Posted From: 76.83.107.215
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 09, 2007 - 2:26 pm: | |
If you don't have radial tires in front the ride will be rougher also. When I changed my 4104 to radials it made a huge difference even though the radial tire pressure was much higher. |
