Transmission fluid Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » May 2007 » Transmission fluid « Previous Next »
dutch (Dutch)
Username: Dutch
Post Number: 62
Posted From: 216.9.250.63
Posted on Wednesday, May 16, 2007 - 6:56 pm:
I get mixed recommendations for my transmission fluid for my gm4106 1964 .
What do you recommend fellow nuts????
Username: Pvcces
Post Number: 1087
Posted From: 65.74.65.197
Posted on Wednesday, May 16, 2007 - 9:31 pm:
Dutch, it takes motor oil, the same as the engine, unless you want to experiment.
For what it's worth.
Suncatcher
Ketchikan, Alaska
Username: Gusc
Post Number: 351
Posted From: 71.112.176.74
Posted on Wednesday, May 16, 2007 - 10:32 pm:
If it is the same as the 4104, and I believe it is, it takes 50wt Aviation Grade oil which is mineral oil, or break-in oil in aircraft engines.
These transmissions have oil pumps so 90wt gear lube should never be used.
All this is in the lube section of the manual.
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 34
Posted From: 24.33.85.105
Posted on Wednesday, May 16, 2007 - 10:57 pm:
I HAVE 62 4106 with 8v71...use same as engine...in my case straight 30...is what my original manual says although most guys use 40w. I am told should be same in both engine and tranny on either weight.
Username: Rjlong
Post Number: 1233
Posted From: 67.181.161.137
Posted on Friday, May 18, 2007 - 1:15 am:
Dutch -
Per the shop manual - use the same oil you use in the engine. Simple.
However, this is one area where, if you want to spend the $$$, you can use straight 40wt synthetic oil with no harm, and possibly some improvement.
FWIW & HTH. . .
Username: Gusc
Post Number: 354
Posted on Saturday, May 19, 2007 - 7:33 pm:
This is a puzzle to me. I assume the trans are the same in both the 4104 and 4106 but the oil is different? But maybe they aren't the same.
Very interesting!
Username: Chessie4905
Post Number: 561
Posted From: 71.58.117.21
Posted on Saturday, May 19, 2007 - 7:45 pm:
They are different....the angle drive is on the front of the 06, and on the rear of the 04. Don't know about the internals, without a parts book, as I've never had one apart.
Username: Rjlong
Post Number: 1235
Posted on Saturday, May 19, 2007 - 11:25 pm:
Gus -
The powertrain layout is different between the 4104 and the 4106, as John pointed out.
The 4104 is set up engine, clutch, transmission, bevel gears, drive shaft, rear axle.
The 4106 is set up engine, clutch, bevel gears, transmission, drive shaft, rear axle.
GM had to move the bevel gears when they discovered the greater torque output of the 8V71 was destroying the original design as used in the 4104.
The rear axle pumpkins are also off-set differently, another change made with the introduction of the V-8.
And, as I just posted in the other thread, they changed the transmission oil requirements at the same time, too.
FWIW & HTH. . .
Username: Gusc
Post Number: 357
Posted on Sunday, May 20, 2007 - 12:08 am:
I knew the powertrain lineup was different but does that mean the trans are different? My guess it that it isn't but that is only a guess.
Username: Rjlong
Post Number: 1236
Posted on Sunday, May 20, 2007 - 12:39 pm:
Gus -
What's the model number of your Spicer?
I'll take a look at my '06's on Tuesday and we'll compare. . .
Username: Gusc
Post Number: 358
Posted on Sunday, May 20, 2007 - 7:55 pm:
Russ,
I'll have a look tomorrow, it's raining right now and it is parked a block away near my son's home in Seattle.
Username: Pvcces
Post Number: 1090
Posted on Monday, May 21, 2007 - 8:19 pm:
Gus, the transmission number in our coach is Spicer 7145VC. I'm sure that the 4104 uses a different transmission because the bevel gears in the 4106 are built into the nose of the gearbox and the 4104 has them built into output side of the case.
Tom Caffrey
Username: Gusc
Post Number: 361
Posted on Tuesday, May 22, 2007 - 12:04 am:
Tom,
Sorry I haven't looked yet but have been very busy. I'll try to get to it tomorrow but you're probably right. I'm still curious though.
Username: Gusc
Post Number: 362
Posted on Tuesday, May 22, 2007 - 12:25 am:
Tom,
Curiousity got me so I went out in the rain and checked, it is a Spicer 7141-A. That must have been the end of the 50wt pumpers.
