Gerald Norman (Gnorman46)
Registered Member Username: Gnorman46
Post Number: 35 Registered: 12-2006 Posted From: 143.166.226.42
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 22, 2007 - 9:54 am: | |
I am wondering about the felt in the windows on my 4104, when it rains the slides for the windows fill with water, will replacement felt resolve this or is there something else in the slide to seal the window. Also does anyone know the trick for removing the windows from the slides, I removed the stopper and tried to remove the glass at different spots on the slide with no luck. |
Arthur J Griffith (Arthurseagle)
Registered Member Username: Arthurseagle
Post Number: 26 Registered: 8-2006 Posted From: 72.236.102.197
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 22, 2007 - 5:06 pm: | |
Gerald- There should be one or more drain holes somewhere on the outside of the slider frame. They do plug up over time. Unplug the holes and the water should flow out. GOOD LUCK. ARTHUR |
David B. Sweet (Sweets4104)
Registered Member Username: Sweets4104
Post Number: 3 Registered: 2-2007 Posted From: 64.136.49.227
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 22, 2007 - 7:45 pm: | |
Check with glass shops, they are usually very helpful in locating goodies. Blessings, David PD4104-2977 Winton, CA. |
J.L.Vickers (Roadrunnertex)
Registered Member Username: Roadrunnertex
Post Number: 22 Registered: 10-2006 Posted From: 76.1.64.165
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 22, 2007 - 9:02 pm: | |
Remove the 2 top screws from the angled bar on the window. The windows will come out after the top 2 screws are removed. |
Jim Rink (Fakeguy)
Registered Member Username: Fakeguy
Post Number: 35 Registered: 1-2005 Posted From: 24.33.85.105
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 22, 2007 - 9:18 pm: | |
I got replacement felt from Luke at US COACH for my '62 4106...don't know if windows are the same but they look like it. either way, Luke would know. don't have phone number with me but can look up and post in the next couple days |
Austin Scott Davis (Zimtok)
Post Number: 126 Registered: 9-2006 Posted From: 216.37.73.226
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 23, 2007 - 8:36 am: | |
Lukes info is in the "Last Lost Links Link" section of this website. (On the main page) His number listed there is 1.888.262.2434 Luke is a great guy to deal with. . |
Jim Wilke (Pd41044039)
Post Number: 140 Registered: 2-2001 Posted From: 69.77.144.142
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 23, 2007 - 9:57 am: | |
Gerald, the drain holes are at the bottom of the frame the windows slide in. They drain into the space under that hinged aluminum frame. On my bus someone had tightly caulked the gap around that swing out frame causing the water to drain inside the bus. I had to cut a couple of holes in the sealer at the bottom to let the water out & the problem went away. (AFTER ruining my wall paneling & rotting the floor!) Jim-Bob |
Post Number: 36 Registered: 12-2006 Posted From: 68.241.193.68
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 27, 2007 - 5:16 pm: | |
Thanks, the drain holes are most likely my problem along with the metal & rubber piece that goes on the sliding windows, I am sealing the windows so they dont swing out and replacing the rubber seals with a rubber sealant, the sealant is 1/4 thick at the back so normal drainage shouldn't be a problem and I wont need the rubber inserts that extend into the interior. I am leaving the hinges on in case we ever need to get them open. I will clean out the drains or make new ones if needed. Thanks again. One other question, on the actual windows I see a rubber insert in the frame of the induvidual windows, is the something I can replace with a generic rubber or is there something special I need for it, I considered ordering all the correct parts from Luke at US Coach but it would be pretty expensive for all the windows and they dont have all the parts needed. |
