Robert Chamuler (Nemos88)
Registered Member Username: Nemos88
Post Number: 24 Registered: 8-2006 Posted From: 76.104.145.36
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 25, 2007 - 9:46 pm: | |
What is the proper procedure for placing the 4 speed spicer in reverse? Hit the reverse switch and move the stick from neutral to 2nd/reverse? or is there another procedure. Whatever I am doing I can not seem to get it in reverse. I checked the solonoid and it moves the lever about an inch. Should it move more than that? Thanks |
Douglas Wotring (Tekebird)
Post Number: 182 Registered: 10-2004 Posted From: 71.59.75.212
Rating: ![](http://www.busnut.com/bbs/icons/s111111111.gif) Votes: 1 (Vote!) | Posted on Friday, May 25, 2007 - 9:59 pm: | |
put it in first, hit the switch and put into 2nd/reverse |
Post Number: 570 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 25, 2007 - 10:05 pm: | |
If the linkage is out of line a little or a weak solenoid will cause that if you are doing it like Doug mentioned and it still doesn't want to go in. |
Post Number: 6 Registered: 5-2007 Posted From: 64.40.223.242
The procedure you described is exactly how it says to put it in reverse, my Eagle manual. Once in reverse remove finger from button, engage clutch. Do Not Leave Button pushed in, could damage the solenoid coil. I do not how far it should move the lever though. You might try moving the shift lever from any gear, back to neutral, hit switch, engage cluth, move to second (reverse). Hope this helps some. |
Post Number: 571 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 25, 2007 - 10:06 pm: | |
will it go in if someone helps the solenoid? |
Post Number: 183 Registered: 10-2004 Posted From: 71.59.75.212
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 25, 2007 - 10:25 pm: | |
if you don't start the process in first it will not go into Rev. |
Post Number: 117 Registered: 12-2000 Posted From: 71.30.227.12
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 25, 2007 - 11:14 pm: | |
The procedure from the book is to put it in first gear, then operate the switch, then put it in second gear and release the switch |
Post Number: 7 Registered: 5-2007 Posted From: 64.40.223.242
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 25, 2007 - 11:45 pm: | |
Len, Why is it differant on my Eagle? Same transmission and solenoid, or are they totally differant. Because my book says differant. Just would like the correct answer. Or are we both correct? |
Post Number: 118 Registered: 12-2000 Posted From: 75.89.16.28
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 26, 2007 - 10:16 am: | |
I really don't know why the instructions would be different, it is the same trans. Perhaps shifting into first makes sure the trans has stopped spinning before going into reverse. I don't think it makes a lot of difference. If it shifts smoothly into reverse by whatever method you are using, it should be OK. Len |
Post Number: 8 Registered: 5-2007 Posted From: 64.40.223.242
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 26, 2007 - 12:16 pm: | |
Len, Thanks for the information. I just wanted a clarification in case of a miss print. Really did not want to screw it up. Your point abut spinning makes sense, although I think I will continue the way my manual describes to shift into reverse. Opinions of others are important to me, as I have only owned my Eagle for 4 years. Many more have much more experience than I. Paul |
larry currier (Larryc)
Post Number: 106 Registered: 2-2007 Posted From: 64.12.116.203
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 26, 2007 - 5:36 pm: | |
Robert, sometimes the bolts that hold the solenoid on become loose. If this happens the arm will not move enough to engage second. The arm from the solenoid was worn on my 05 and I had to fill some air space between the two with baling wire wrapped around at the arm. That was 10 years ago, so the baling wire is still working. |
David B. Sweet (Sweets4104)
Registered Member Username: Sweets4104
Post Number: 4 Registered: 2-2007 Posted From: 64.136.26.225
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 28, 2007 - 7:01 pm: | |
I have found with my PD4104, when I shift into first, then actuate the reverse switch, I can feel the solenoid in the shift lever as it sets itself for reverse, then I proceed from first to the 2nd gear position and reverse. |
Post Number: 26 Registered: 8-2006 Posted From: 76.104.145.36
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 30, 2007 - 9:37 pm: | |
Thanks for all your input. Placed her in first, hit the switch and she went if reverse. yahooo |
Jerome Dusenberry (Jerry32)
Registered Member Username: Jerry32
Post Number: 22 Registered: 1-2007 Posted From: 148.78.243.51
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 03, 2007 - 7:20 am: | |
I have a book from a 4905 that says to start in nuetral and then push the button and go to first and then second then release. Seems thare are many different ways. Jerry |
