Radiator replacement Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » May 2007 » Radiator replacement « Previous Next »
Robert Cox (Bob05)
Username: Bob05
Post Number: 3
Posted From: 75.14.223.10
Posted on Friday, May 25, 2007 - 5:37 pm:
Where would one find the best radiator for the money for a 1968 Eagle? at this point that's where I think I need to start with the 8v71/8v92 change over. also running 740 allison tranny now ( asking the experts)
Username: Drivingmisslazy
Post Number: 1909
Posted From: 75.108.86.248
Posted on Friday, May 25, 2007 - 7:28 pm:
I would recommend you get the largest that you can fit in. I never totally eliminated my overheating problems when I put an 8V92 in my 80 Eagle. And I did install a big, new radiator.
Username: Jackconrad
Post Number: 581
Posted From: 76.1.180.218
Posted on Friday, May 25, 2007 - 7:29 pm:
In addition to a new radiator, you might want to consider adding an auxillary transmission cooler. Although we did not change engines , our 8V71 with 740 tranmission runs about 10 degrees cooler since we added the auzillary transmission cooler. Hope this helps, Jack
clark lane (Bus05eagle)
Username: Bus05eagle
Post Number: 9
Posted From: 74.32.85.140
Posted on Friday, May 25, 2007 - 7:56 pm:
Bob,the radiator for the 05 with a 8v92 needs to be 47in wide 40in tall and 6 rows of core that is what mine is with a 32in fan and it came from eagle in 1994 you will lose the battery box on that side because of the size of the radiator i have no cooling problems and have no extra cooler for the transmission if you can find a Mann transit bus they have the same radiator this is what Joe Larid used in his 05 with a 8v92 joe doesn't post on this board any more but does on the mak board sometimes good luck and do it right the first time and you will not have any problems
Robert Cox (Bob05)
Username: Bob05
Post Number: 4
Posted on Saturday, May 26, 2007 - 6:39 pm:
Another thought I'm running 9A90 injectors would downsizing help with my heating problem?
and what would be the sugested size?
