Cam bearing removal? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » May 2007 » Cam bearing removal? « Previous Next »
carl white (Carl_mci_9)
Username: Carl_mci_9
Post Number: 18
Posted From: 208.108.101.210
Posted on Wednesday, May 30, 2007 - 1:15 pm:
I am trying to remove the front cam bearing on my 8v71.
The first one came off with little trouble the second one I cann't move it at all.
The triangle bearing holder is to close to the block to get a traditional wheel\bearing puller under it to get it off.
Has anyone had this problem and how did you finaaly get it removed
Thanks Carl
larry currier (Larryc)
Username: Larryc
Post Number: 111
Posted From: 64.12.116.203
Posted on Wednesday, May 30, 2007 - 11:26 pm:
I think you need a special tool. It will allow you to remove the bearings and also install the new ones. I don't think you can do the work without the tool.
guy bouchard (Guy_bouchard)
Username: Guy_bouchard
Post Number: 9
Posted From: 161.184.179.138
Posted on Wednesday, May 30, 2007 - 11:45 pm:
There should be no special tool needed. I assume you are having trouble with the dry bearing (opposite water pump). There is a gasket behind that bearing and it was probably glued down on both sides. If you look closely you will see some little notches midway between the bolt holes. A little crowfoot bar and GENTLE tapping should get it moving. Good luck
Guy 4905
