Jim Schrecengost (Schrec)
Registered Member Username: Schrec
Post Number: 23 Registered: 2-2007 Posted From: 24.2.127.5
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 03, 2007 - 10:32 am: | |
Does anyone know how hot the engine compartment bulkhead gets on the inside??? I am thinking of putting a layer of 1/2" blueboard over the whole area and wanted to make sure it wouldn't get to hot. If it would can you give me some other info for isulation and sound proofing, putting in a back bedroom with a queen size bed. Thanks Schrec |
Ron Walker (Prevost82)
Post Number: 299 Registered: 11-2003 Posted From: 69.19.14.40
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 03, 2007 - 12:09 pm: | |
Are you planning to put it in the interior side of the bulkhead or engine side. If you had an engine fire with SM insulation it would melt no matter which side you put it on filling the coach with toxic fumes. I used Roxul Insulation on the interior side of the bulkhead. I use this because it's sound and fire proof (won't burn at high temp). Ron |
Post Number: 24 Registered: 2-2007 Posted From: 24.2.127.5
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 03, 2007 - 12:25 pm: | |
putting it on the inside. where do you get this roxul insul;ation and is it expensive? |
JC Alacoque (Jc_alacoque)
Registered Member Username: Jc_alacoque
Post Number: 32 Registered: 7-2006 Posted From: 154.11.109.30
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 03, 2007 - 2:44 pm: | |
Heat wise, you could use the insulating blankets made for exhaust systems. They come in various dimensions. That would work pretty well. Or wrap up your whole exhaust system, like I just did. Makes a big difference. |
Post Number: 365 Registered: 11-2005 Posted From: 63.97.117.13
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 03, 2007 - 10:45 pm: | |
Try EHP, they make great stuff of all types and thicknesses. A bit costly but it will never burn. |
Post Number: 118 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 03, 2007 - 11:02 pm: | |
Jim Roxul is readily available here in (Can) in all the large homebuilding supply stores. Not sure about stateside. Joe. |
Post Number: 300 Registered: 11-2003 Posted From: 208.181.210.47
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 12:15 am: | |
and it's not that much more than regular fiberglass insulation. Home Depot sells it Ron |
Simon Ayriss (Design_dog)
Registered Member Username: Design_dog
Post Number: 32 Registered: 3-2007 Posted From: 69.233.8.116
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 12:26 am: | |
which Roxul product is a good way to go with? they have it in boards with different thicknesses and blanket in different thicknesses? Industrial Board * RHT™ 100 Industrial Board * RHT™ 120 Industrial Board * RHT™ 40 Industrial Board * RHT™ 60 Industrial Board * RHT™ 80 Industrial Board RW Blanket Insulation * RW™ 40 Blanket * RW™ 60 Blanket * RW™ 80 Blanket Ron and Joe. or anyone else, did you guys do your entire bus insulated in Roxul?? or just the back? Gus. EHP looks very interesting. It looks fireproof as heck but I am puzzled as to how it is or how it would venture with sound and heat, etc. Its so weird it seems like insulation is getting thinner and thinner these days. I would have to assume you need other insulation on top of that or no? |
Post Number: 301 Registered: 11-2003 Posted From: 208.181.210.47
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 2:56 pm: | |
No I did the engine bulk head at the rear of the bus and I did my generator compartment with it. Unlike some insulation Roxal fire proof and a sound barrier (Message edited by prevost82 on June 04, 2007) |
Post Number: 593 Registered: 12-2000 Posted From: 67.142.130.30
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 3:40 pm: | |
We have a thermister near the top of the engine compartment directky above tge 8V71 in our MC-8. This is connected to the RV Safety Systems alarm panel near the driver. The engine compartment run 135*-150* depending on outside air temperature and engine load. We have never seen the tenperaqture exceed 150*. Jack |
