dounan p. morton (Dounan04)
Registered Member Username: Dounan04
Post Number: 8 Registered: 11-2004 Posted From: 24.34.39.213
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 11, 2007 - 7:16 pm: | |
does anyone know of 1 for sale on the east coast? thanks |
Post Number: 583 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 11, 2007 - 7:30 pm: | |
Dean's Coach Durham NC; Luke's in New Berlin NewJersey |
Post Number: 9 Registered: 11-2004 Posted From: 24.34.39.213
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 11, 2007 - 7:49 pm: | |
thanks , would you happen to know if there is any other trans. that will bolt up to and work in a stock 04. i searched the archives and found nothing. i'm looking for just a little more than direct drive. |
James Stacy (Jimstacy)
Post Number: 54 Registered: 1-2001 Posted From: 75.41.2.152
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 11, 2007 - 10:32 pm: | |
IIRC the 4th gear ratio in the stock 4104 Spicer is an overdrive; taller gear even than the V730 overdrive ratio. The stock rear axle ratio is 4.10 (or 4.11 depending on mfg). Only other stock gear that will fit is the 4905 stock ratio of 4 3/8th. Seems you already have the tallest stock gearing I know of. I believe even the Hydroshift option gave a lower ratio in each gear position rather than a taller one. Someone that's intelligent might correct here me as I'm going from memory. (A very old memory). How about taller tires? Jim Stacy |
Post Number: 1249 Registered: 12-2000 Posted From: 67.181.189.94
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 11, 2007 - 11:42 pm: | |
Dounan - Why do you need a new engine cradle? There is no other manual gearbox that will work with the stock powertrain in the 4104. This has been hashed over numerous times on this and other busnut bulletin boards. The same goes for an automatic - you have your choice of the older two-speed VS2 or the newer three-speed V-730. Either way, you need to change to a 4106 or later rear axle to accomodate the different driveshaft offset. A 6V92TA / V-730 / 4106 rear axle has been a common and successful powertrain swap in the 4104s. Jim - For your (and other busnut's) information, here are the transmission ratio tables for the GMC Parlor Coaches:
Stock 4104 Drive Train | | | | | Gear | Ratio | Bevel Gear | Rear Axle | Overall | 1st | 3.86:1 | 1:1 | 4.125:1 | 15.923:1 | 2nd | 2.50:1 | 1:1 | 4.125:1 | 10.313:1 | 3rd | 1.50:1 | 1:1 | 4.125:1 | 6.188:1 | 4th | 1.00:1 | 1:1 | 4.125:1 | 4.125:1 | Rev | 3.29:1 | 1:1 | 4.125:1 | 13.571:1 | | Optional (and VERY RARE) 4104 Drive Train | | | | | Gear | Ratio | Bevel Gear | Rear Axle | Overall | 1st | 3.86:1 | 1:1 | 3.56:1 | 13.742:1 | 2nd | 2.50:1 | 1:1 | 3.56:1 | 8.90:1 | 3rd | 1.50:1 | 1:1 | 3.56:1 | 5.34:1 | 4th | 1.00:1 | 1:1 | 3.56:1 | 3.56:1 | Rev | 3.29:1 | 1:1 | 3.56:1 | 11.712:1 | | Stock 4106 & 4107 Drive Train | | | | | Gear | Ratio | Bevel Gear | Rear Axle | Overall | 1st | 3.86:1 | 0.808 | 4.125:1 | 12.865:1 | 2nd | 2.50:1 | 0.808 | 4.125:1 | 8.333:1 | 3rd | 1.50:1 | 0.808 | 4.125:1 | 5.00:1 | 4th | 1.00:1 | 0.808 | 4.125:1 | 3.33:1 | Rev | 3.29:1 | 0.808 | 4.125:1 | 10.966:1 | | Stock 4108 & 4905 Drive Train | | | | | Gear | Ratio | Bevel Gear | Rear Axle | Overall | 1st | 4.28:1 | 0.808 | 4.375:1 | 15.130:1 | 2nd | 2.50:1 | 0.808 | 4.375:1 | 8.838:1 | 3rd | 1.50:1 | 0.808 | 4.375:1 | 5.303:1 | 4th | 1.00:1 | 0.808 | 4.375:1 | 3.535:1 | Rev | 3.29:1 | 0.808 | 4.375:1 | 11.630:1 | | I just picked up on something here. . . for a long time, lots of busnuts have complained about the rather tall first gear in our coaches. I've always just looked at the 4104 and 4106 charts, never really paying any attention to the 40-foot 4905's gearbox. But look closely - first gear is actually LOWER than that of the others! Hmmmm. . . I might just start looking for one of those!! Sorry, they don't fit the 4104s, sadly. FWIW & HTH. . .
Post Number: 10 Registered: 11-2004 Posted From: 24.34.39.213
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 12, 2007 - 6:29 am: | |
rj, i want another cradle because i have access to just about enough part to put together a turbo-6-71. so i would like to put together a whole cradle package to hold in reserve. For next time mine gives me any trouble, or when i get bored, whichever comes first. thanks all for the info dounan |
Post Number: 11 Registered: 11-2004 Posted From: 24.34.39.213
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 12, 2007 - 7:26 am: | |
what exactly is the hydrashift unit i've read about? is it a trans or something between the engine and trans ? does it reside in a stock bell housing? are they unattainable? what is the final drive ratio? is it more than 1 to 1 ? |
Jack Campbell (Blue_goose)
Post Number: 7 Registered: 5-2007 Posted From: 71.101.55.168
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 12, 2007 - 7:45 am: | |
The hydroshift is a compleat transmission. They are hard to find. You have all the gears that you need if you have one. One of my good friends used one and worked on the also. He has gone on to better places now and I have no idea where you could find one. Some of the oldtimers should know where to find one. |
Post Number: 55 Registered: 1-2001 Posted From: 75.40.234.158
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 12, 2007 - 10:33 am: | |
RJ, thanks for the ratio info. Thats what happens when relying on memory (which my wife said was the second thing to go. I don't remember the first). The Hydroshift was a rare factory option. It consisted of a planetary gearset and two clutches all mounted in the original bellhousing. Without my maintenance book to verify, I believe it gave a lower gear ratio available in each gear. It acted like a splitter box giving 8 possible forward gears. I'll have to check "Da Book" to verify gearing. I know it is in my 4104 maintenance manual in the rear section on options. It turned out to be a fragile design according to Garry Dean and most were removed from service because of downtime. Very unusual to find one today. FWIW Jim Stacy |
Post Number: 585 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 12, 2007 - 5:05 pm: | |
We used to have one years ago...it gave an overdrive in each gear of about 25 to 30 percent. Worked good with 4:11, perfect with 4;56. I'll bet that the parts are from the VS series automatics except for a few items. Good Luck finding one. The best deal would be for someone to make a compact unit that would go behind trans. Since the drive shaft is about 4ft. long, there is room.The 4104 parts book lists a 3 7/8 ratio, but I've never seen it. |
Post Number: 56 Registered: 1-2001 Posted From: 75.40.233.32
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 12, 2007 - 8:03 pm: | |
True on the 3 7/8 ratio. I was never able to find one even with Dean's Coach doing the change. BTW the 4104 rear axle works fine with the newer final drive units, at least with a V730. We installed an RTS cradle with the 6V92TA aboard so we were able to control the right to left positioning. (6V is much shorter overall than the inline 6). As a matter of fact, when we were done we discovered we could have easily put in an 8V92. Put it in maybe, kept it cool, probably not. It's worked fine for nearly 100,000 miles. The 4 1/8 (4.125) ratios varied slightly depending on supplier. I counted teeth on several samples. One I remember was 41/10 (4.10) and another was 37/9 (4.11). Not enough to be noticeable but just for interest. Jim Stacy |
