FAST FRED (209.26.110.197)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 14, 2001 - 3:14 am: | |
IF you find a coach in fairly nice shape , it should only need parts as you renew and upgrade. When you do the front end , New bearings and brake blocks ect will work better than used. Same for any area you get into. Purchase the Maint book and if your going to do a conversion , rather than a total shell cleanout , the parts book has info on what is behind the walls and ceiling , to attach stuff ect. Body skin is avil fresh , but if you start on that road {new and shiney}it gets expensive fairly quickly. If you do a real good service when you get the coach {by Da Book} you will know if hard part$ { rear end , tranny } are OK . FAST FRED |
