Air dryer installation Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » June 2007 » Air dryer installation « Previous Next »
mark (Coolbus)
Username: Coolbus
Post Number: 63
Posted From: 71.54.203.149
Posted on Sunday, June 17, 2007 - 2:15 am:
I am thinking about installing an air dryer on the bus. Can somebody tell me about the installation - never done it before. Is there a certain location where the dryer has to be plumbed in? Or can it go anywhere in the system?
Thanks
Mark
John Jewett (Jayjay)
Username: Jayjay
Post Number: 372
Posted From: 75.14.14.68
Votes: 2 (Vote!)
Posted on Sunday, June 17, 2007 - 3:30 am:
Try www.bendix.com. Their Site covers all of their models, installation instructions, etc. Info included would apply any brand. if you operate in cold country, pick a model with a heater built in. Stops the moisture removed from clogging the vent when it freezes. Cheers...JJ
Glenn Vining (Glennvin)
Username: Glennvin
Post Number: 22
Posted From: 75.90.8.68
Posted on Sunday, June 17, 2007 - 9:08 am:
Hi Mark,
You gonna want to locate the dryer as far away from the compressor as possible. This usually means up around the front on a bus. This will give the air time to cool before it reaches the dryer.
As John stated above, the Bendix site will help a lot.
Workin' til He comes,
Glenn
Username: George_mc6
Post Number: 196
Posted From: 76.168.69.233
Posted on Sunday, June 17, 2007 - 12:28 pm:
Morning Mark,
I too suggest you go to the Bendix site, they have been at it for a while, and know what they are doing. Download the portion of the handbook that lists models of air dryers, if you don't have hi-speed internet, and don't want to take the time to download a large file.
Then, pay close attention to their schematic diagram, and do as they say, which is in contravention to the above post. They actually provide piping length requirements for cooling, according to air usage, but the dryer HAS to go between the compressor and the first reservoir, or it won't do much good.
HTH, George
Username: Dreamscape
Post Number: 15
Posted From: 64.40.223.242
Posted on Sunday, June 17, 2007 - 12:36 pm:
Compressed air heats up thus creating moisture in the system. The closer the dryer to the compressor would be best. Less moisture equals fewer problems and rusting/gumming of parts. As stated before check the Bendix site before you do anything.
Username: Chessie4905
Post Number: 598
Posted From: 71.58.117.21
Posted on Sunday, June 17, 2007 - 2:12 pm:
Bendix recommends at least 6 feet away with a downhill slope to the line, preferably copper to dissipate the heat. My other 4905 has one up front by the end of the fuel tank on the driver's side.
Username: Gusc
Post Number: 377
Posted From: 63.97.117.18
Posted on Sunday, June 17, 2007 - 5:58 pm:
Glenn is right. Heating the air doesn't cause moisture, cooling it does. It is called condensing.
Ron Walker (Prevost82)
Username: Prevost82
Post Number: 307
Posted From: 208.181.210.47
Posted on Sunday, June 17, 2007 - 11:25 pm:
Hi Mark .. on my Prevo it's mounted just behind the tag axle on the curb side. It's plumbed with a 6ft steel braided hose from the compressor on a down hill slope into the dryer. Then it goes into the wet tank which should be above the drive axle
Ron
(Message edited by prevost82 on June 17, 2007)
JR Lynch (Njt5047)
Username: Njt5047
Post Number: 166
Posted From: 69.132.237.9
Posted on Monday, June 18, 2007 - 10:10 pm:
FWIW, MC9s have the dryer mounted ahead of the front axle. That is a looong way from the compressor.
However, it works well in this position.
Purge valve sure is easy to hear!
I check the air tanks occasionally and have never had any oil or water in any tank.
I have a question about the dryer purge valve...does shop air application, if the pressure reaches the purge pressure (120 lbs in my bus) will the purge valve cycle? That would be bad if working in that area. I've spent a good deal of time under the front axle looking for leaks.
Cheers, JR
Post Number: 1028
Posted From: 70.53.131.78
Posted on Tuesday, June 19, 2007 - 10:20 am:
Hello.
Heat is bad for the air dryer desicant. That is why there are minumum runs away from the air compressor, so you don't bake the desicant, rendering it ineffective.
So, further away, the cooler the incoming charge, the better for the dryer.
JR, yes, your shop air would be able to generate a purge cycle if the air system's pressure is cycling up and down.
If the air pressure in the coach drops so that the governor cuts in, and then your shop air builds beyond the governor's cut-out, you will get a purge from the air dryer. The governor is a spring type device that does not care whether the engine is running. It reacts to the air pressure pushing, or not, on its internals.
The air compressor governor is what controls the purge valve in the air dryer using a pneumatic signal line.
In order to have a quiet visit under the front of the coach, a simple option is to lower your shop air pressure below your coach's cut-out pressure.
JR Lynch (Njt5047)
Username: Njt5047
Post Number: 168
Posted on Tuesday, June 19, 2007 - 11:32 pm:
Thanks Buswarrior...I sorta thought that was a possibility, so the shop air is set to 100 lbs. 120 lbs is gov set point.
I don't recall it purging on shop air, but the regulator has always been set at 100 lbs.
I'm already blind in one eye...sorta like to keep the other!
Worried more about overpressurizing the air system than thinking about the purge valve. Spent many an hour looking for leaks. That's a lost cause.
Thanks, JR
John Harrelson (Jharl)
Username: Jharl
Post Number: 52
Posted From: 72.73.67.180
Posted on Friday, June 22, 2007 - 8:40 pm:
Buswarrior you look cold
Post Number: 1033
Posted From: 74.12.74.111
Posted on Saturday, June 23, 2007 - 7:04 pm:
Yup, makes the summer sun feel just a bit better with that frosted picture on there...
beverage anyone?
