John Lacey (Junkman42)
Registered Member Username: Junkman42
Post Number: 9 Registered: 3-2007 Posted From: 204.49.140.133
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 18, 2007 - 7:10 pm: | |
can anyone tell Me if a stewart warner tach 825 hz can be used on My mc7. Any other suggestions for a tach. Also noticed that My speedo is pulsing, is it mechanical or electric. Thanks John Lacey |
JC Alacoque (Jc_alacoque)
Registered Member Username: Jc_alacoque
Post Number: 33 Registered: 7-2006 Posted From: 74.127.203.95
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 18, 2007 - 9:43 pm: | |
I just replaced the speedo sensor on our hockey team's 102D3. It reads 4 bolts mounted on the back of the driver's side front brake drum. It was pulsing and jumping at first. I backed it off a little at a time per the service manual's instructions and is now fine. The speedo on my Courier 96 pulses too. It is off the manual transmission. I can't see any adjustment there. I haven't had a chance to look at the speedo proper yet for adjustment. So I haven't solded that one yet. |
Ron Walker (Prevost82)
Post Number: 312 Registered: 11-2003 Posted From: 208.181.210.47
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 19, 2007 - 1:26 am: | |
I have a tach sensor on the bottom of my bell housing picking up the starter ring gear teeth. You can also run off the alternator. Ron |
