RJmule (Rjmule)
Registered Member Username: Rjmule
Post Number: 102 Registered: 2-2007 Posted From: 75.51.66.117
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 21, 2007 - 1:13 am: | |
Use series & parallel wiring in combination This diagram shows a combination series and parallel circuit to increase both the battery current and voltage level at the same time. Assume this time we are using 12 volt batteries. The left to right series connection add the two 12 volt batteries to make 24 volts. And, since we did this 3 times and then connected each group of 2 (now 24 volts) in parallel we end up with one very large 24 volt battery. It has twice the voltage of a single 12 volt battery and 3 times the current or power because all 3 groups are wired in parallel. Using series and parallel in combination to increase both current and voltage. |
