Inside the fresh/gray/black water bay Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » June 2007 » Inside the fresh/gray/black water bay « Previous Next »
WILLIAM D. WATKINS (Sivrtnge2)
Username: Sivrtnge2
Post Number: 66
Posted From: 76.97.110.75
Posted on Thursday, June 21, 2007 - 4:42 pm:
Hi all,
MY wife and I just got through removing the fresh and Black water tanks from the bay. It looks like a spider web there with all of the water hoses and electrical lines running every direction. Can you all please post some pictures of your water bays to show how clean looking they could be. This project was origonally an a/c removal and replacement. My new a/c units wouldn't work unless I reduced the size of my water tanks. Now I am "re--remodeling" my coach.
BILL
Username: Dnick85
Post Number: 124
Posted From: 75.197.252.150
Posted on Thursday, June 21, 2007 - 6:40 pm:
Hi Bill,
You asked for some.....
Nick-
Username: Dnick85
Post Number: 125
Posted on Thursday, June 21, 2007 - 6:47 pm:
And the other side of the tank compartment
Username: Sivrtnge2
Post Number: 67
Posted on Thursday, June 21, 2007 - 8:11 pm:
Thanks for the pictures Nick!!!
Can you describe what i,m looking at here? It looks to me that you have a tank gauge. I take it that the smaller tank is your fresh water
tank. How big is your tanks??? How do the cruise are work??? What can I use for my drivers air without running the genset? I do not have bus ac anymore. Sorry for so many ???s but I need the knowledge!!!
BILL
Username: Dnick85
Post Number: 126
Posted on Thursday, June 21, 2007 - 9:52 pm:
Hi Bill,
The two big tanks are Fresh water and gray water at 105gal each. The smaller tank is black at 50 gal.
The tank sensors are Sensa Tank RV 100 tank monitoring system by MSC engineering that also sences LP but I don't use LP.
Both gray and black tanks are Y-ed together with seperate dump valves.
My Cruiseair's are selfcontained heat pumps at 15,000btu's each and are more then enough on the hottest days. I don't run them down the road. I use OTR coach air. What I discribed to you in your other thread about installing a car type compressor hooked to your dash evap is the second best way. Third, would be to mount a roof air directly over the drivers area and pipe it to blow on you. But thats about all you will cool is you. Unless you want your wife to sweat.LOL
Good Luck
Nick-
Username: Dnick85
Post Number: 127
Posted on Thursday, June 21, 2007 - 9:57 pm:
Hi Bill,
I don't know if you get BCM magazine but, here is a link to the centerfold site that features my bus.
http://busconversions.com/centerfold.htm
Or you can check out the rest of my build pics at my yahoo site.
http://autos.groups.yahoo.com/group/busshellconverters/
Nick-
(Message edited by dnick85 on June 21, 2007)
Username: Sivrtnge2
Post Number: 68
Posted on Thursday, June 21, 2007 - 10:11 pm:
Thanks again Nick,
Have you done this a/c piping to the driver condenser before. Im sure you have...do you have to insulate the copper tubing from the rear of the coach to the front???
BILL
Ron Walker (Prevost82)
Username: Prevost82
Post Number: 314
Posted From: 208.181.210.47
Posted on Thursday, June 21, 2007 - 10:27 pm:
Hey Bill here some pic's of my water/septic bay
Username: Prevost82
Post Number: 315
Posted on Thursday, June 21, 2007 - 10:39 pm:
Try this again
Curb Side
This is the curb side of the water/septic bay. Hydro-Hot is in front of the tank. Toilet pipe is in the middle left of the picture.
(Message edited by prevost82 on June 21, 2007)
Username: Prevost82
Post Number: 316
Posted on Thursday, June 21, 2007 - 10:53 pm:
One more ... above is water/septic bay on curb side with Hydro Hot in front. Septic is on the left on water is on the right.
This is Driver side water / septic bay ... water is on the left septic on the right. I had a custom made tank ... they glue the plastic sheet together and welded in the baffles then fiberglas each tank then put the 2 tanks together and reapplied more fiberglass, they also fiberglass a piece of 3/4 plywood on this end (shown above pic)to mount pumps etc on. The 2 black pipes (on each side) coming from the ceiling and through the floor are the vents, on the post before this one you can see another black pipe also that is another septic vent, one on each side of the bus. Hope this helps
Ron
Username: Sivrtnge2
Post Number: 69
Posted on Thursday, June 21, 2007 - 11:56 pm:
Thanks Ron,
I appreciate the pictures, I'm trying to show the "Bank" (my wife) how neat these bays should be!!!
BILL
Username: Prevost82
Post Number: 317
Posted on Friday, June 22, 2007 - 12:36 am:
Yea Bill your not alone ...I have the "Bank" problem too.
Ron
Username: John_mc9
Post Number: 394
Posted From: 68.205.165.5
Posted on Friday, June 22, 2007 - 1:14 am:
You guys should just take the time to learn what interest the banker needs......
Username: Sivrtnge2
Post Number: 70
Posted on Friday, June 22, 2007 - 8:53 am:
Ive been with my bank for 16 years now...it's not the interest...it's the change up!!!
BILL
Username: John_mc9
Post Number: 396
Posted on Friday, June 22, 2007 - 9:07 am:
44 years.....
(seems like I always get in the wrong line~~~~~~*^ )
(HAR)
Username: Prevost82
Post Number: 318
Posted on Friday, June 22, 2007 - 10:00 am:
Yea I'm going on 18 yrs. I did buy a new flexsteel ultraleather couch/bed that she "did" want ... but now I haven't got enough money left over to buy anything for me.... funney how that works.
Ron
Username: Chucks
Post Number: 1116
Posted From: 68.240.247.115
Posted on Friday, June 22, 2007 - 10:11 am:
Rube checking in. ;)
tankage
Two 100 gal horizontal tanks - fresh on top, grey on bottom.
I probably would not do that again. I thought the horizontally-oriented would distribute weight better, which is true, but slow to drain when less than 1/2 full.
Door removed in front of piping so that JohnMC9 can peek. ;)
Username: John_mc9
Post Number: 398
Posted From: 66.217.107.34
Posted on Friday, June 22, 2007 - 12:05 pm:
Real neat, Chuck!! Nice job indeed!
Maybe better with the waste tank on the top?
It's an easy fix, tho.... just swap the connections!!
Username: Ace
Post Number: 571
Posted From: 216.9.250.6
Posted on Friday, June 22, 2007 - 7:33 pm:
If you want your tanks to drain fast and clean without rinsing,try round tanks. Ya'll know they worked and are still working for me! :-)
Username: John_mc9
Post Number: 400
Posted on Friday, June 22, 2007 - 8:32 pm:
Ace -
You oughta' post the pictures of your tank arrangement for
William D. That might be how he could fit everything he needs,
into that one bay he wants it all in!
Username: Dnick85
Post Number: 128
Posted From: 75.196.211.216
Posted on Friday, June 22, 2007 - 9:00 pm:
Hi Bill,
To answer your question about the drivers air, yes I have but, not an Eagle to date. You can remove the bus condencer and mount a smaller one in a place of your choice like against your engine radiator, or a ventd compartment with a 12v automotive fan. It's easier to run a new line set to the dash evap. rather then trying to remove the tee's and selonoid. And to answer your question of wrapping the copper lines, just the [large] suction line. There lots of web sites that sell automotive components for your needs. When I get back in my office tomorrow, I will link some to you.
Nick-
Robert Wood (Bobwoodsocal)
Username: Bobwoodsocal
Post Number: 390
Posted From: 76.174.240.245
Posted on Sunday, June 24, 2007 - 9:18 pm:
Wow, Nick your bus is beautiful. Congrats on the centerfold. Bob
Username: Dnick85
Post Number: 135
Posted From: 75.197.97.238
Posted on Sunday, June 24, 2007 - 10:37 pm:
Thank You Mr.Wood!
Bus Nuts are the best....I enjoy being part of this community.
Nick-
