Dennis Tracy (Eagle10)
Registered Member Username: Eagle10
Post Number: 16 Registered: 10-2006 Posted From: 74.75.127.129
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 18, 2007 - 8:35 am: | |
About a month ago, I thought I had a bad fuel issue but it turned out to be something different. I lost power going down the road so I changed fuel filters and it went fine. I also treated the fuel at that time. The next time I tried to start it, it would'nt start and it ended up being the fuel shut off. It was sticking off and sometimes part way off. I pulled my bed and put WD 40 on the pivot point. I worked it about 300 times and now it springs back great. Enjoy the good life. |
Post Number: 47 Registered: 5-2007 Posted From: 64.40.223.242
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 18, 2007 - 10:18 am: | |
Great news. Nice to hear of problems that get fixed and the results. |
Austin Scott Davis (Zimtok)
Post Number: 157 Registered: 9-2006 Posted From: 216.37.73.226
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 18, 2007 - 11:03 am: | |
Great to hear you found the problem. I'm beginning to believe that I will always be chasing down little gremlins with my bus. Nothing big just little annoying things. Just the other day my flashers started flashing irregularly. I thought probably bad ground, turned out to be a bulb. The one filament had burned out and then shorted to the other filament. Grounding through the other filament caused it to flash irregularly. . (Message edited by zimtok on July 18, 2007) |
J.C.B. (Eagle)
Post Number: 124 Registered: 12-2000 Posted From: 209.183.34.48
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 18, 2007 - 5:04 pm: | |
I would suggest that you lubricate that with something like slick 50 or marvel oil as WD40 is not a very good lubricant. |
Justin Griffith (Justin25taylor)
Registered Member Username: Justin25taylor
Post Number: 26 Registered: 4-2007 Posted From: 74.193.73.245
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 21, 2007 - 3:05 pm: | |
J.C.B is right. WD40 will gum up after a while and could make it stick worse than before. WD40 was not intended to be a lubricant. It was meant to displace water and maybe to provide some instant temporary lubrication. Marvel, or 3 in 1 oil would be my choice. plain 30wND motor oil does good too. |
