Throttle Cable Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » July 2007 » Throttle Cable « Previous Next »
Andy Wright (Wrightwy)
Username: Wrightwy
Post Number: 7
Posted From: 75.208.120.76
Posted on Monday, July 23, 2007 - 5:24 pm:
Ok How hard would it be to install a air throttle on my Eagle , I hear the talk about them are the worth the money? The reason I ask is my throttle seems a bit stiff . I thisnormal? Or is there some maintanence that I could do . Thanks Andy
Username: Dreamscape
Post Number: 56
Posted From: 64.40.223.242
Posted on Monday, July 23, 2007 - 5:56 pm:
Remove the access panels in your floor, the linkage runs there. Grease the bearings and if you have a manual transmission do the same. Also check all heater pipe connections. Good time to have a look around. You can also access the top of your fuel tank. This is on my Eagle 01, yours may be differant.
