Jim Rink (Fakeguy)
Registered Member Username: Fakeguy
Post Number: 51 Registered: 1-2005 Posted From: 24.33.84.95
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 27, 2007 - 9:21 pm: | |
Just got home from short trip to columbus oh, from cincinnati. bus sat for about 5 days and ran and handled well. However stopped for fuel at a flying j about half way home and bus appeared to be listing to right front. Air pressure while running was up to about 110 then would drop to 90 and back up to 110...etc etc. After parking at home, appears that it is listing about 4 degrees forward and to the right (passenger side) any clues as to where to start looking...thanks in advance for any help |
Post Number: 371 Registered: 1-2005 Posted From: 208.118.12.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 27, 2007 - 9:30 pm: | |
right front "height control valve leaking" ?? Does a 4106 have valves on each side of the front ?? |
J.L.Vickers (Roadrunnertex)
Registered Member Username: Roadrunnertex
Post Number: 29 Registered: 10-2006 Posted From: 76.1.64.165
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 27, 2007 - 10:57 pm: | |
PD4106 has one leveling valve in the front. Check the ride height on the L/H and R/H rear leveling valves. |
Post Number: 1270 Registered: 12-2000 Posted From: 67.181.189.94
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 28, 2007 - 12:06 am: | |
Jim - JLV's right, it's the rear leveling valves that are causing the list. The shop manual has the specifications for setting the correct ride height, follow them. BUT - Be sure to either do this over a pit or using run-up blocks, do not attempt to do this without, because that chassis can come down VERY quickly, and we don't need to see an obit for a squashed busnut. FWIW & HTH. . .
Jim Rink (Fakeguy)
Post Number: 52 Registered: 1-2005 Posted From: 24.33.84.95
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 29, 2007 - 10:03 pm: | |
Hey, Nuts..thanks for the comebacks...will check the L/H and R/H leveling valves. I have the manauls. |
