Pulsing speedometer Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » August 2007 » Pulsing speedometer « Previous Next »
John Lacey (Junkman42)
Username: Junkman42
Post Number: 12
Posted From: 204.49.140.127
Posted on Monday, July 30, 2007 - 6:22 pm:
Help, I cannot find a description of the speedometer in My mc7 manuals. I would assume that the speedo is mechanical? Anyone have any suggestions on how to lube the cable or is this system possibly electrical? Thanks for all the help and the interesting posts. John
Post Number: 187
Posted From: 4.240.213.170
Posted on Monday, July 30, 2007 - 8:09 pm:
Nice looking coach, John....I know nothing about MCI, but on our Crown, it is a LONG cable...:-(
....and not easy to lube. I started at the transmission end and found other problems, but still have a bit of a "wiggle"
FWIW
James Stacy (Jimstacy)
Username: Jimstacy
Post Number: 81
Posted From: 75.40.226.109
Posted on Monday, July 30, 2007 - 10:57 pm:
John,
I haven't owned an MCI but I do know many have an electrical pickup on the front wheel for the speedo. "Hall effect" sensor. HTH
Jim Stacy
Username: George_mc6
Post Number: 233
Posted From: 207.231.81.129
Posted on Monday, July 30, 2007 - 11:56 pm:
John
Does this only happen below about 10 mph?
Look on the inside of your left front brake drum, for four small magnets, 90 degrees apart, and a "Hall effect" sensor, as mentioned immediately above. The sensor is about an inch and a half long, with two wires coming out of it, and the magnets pass it with about an eighth of an inch or less clearance. At low speeds, my speedo pulses as each magnet passes the sensor. Above 10 or 15, it settles down. If yours is this style, which I think it is, you will have to live with it...
HTH,
George
Ron Walker (Prevost82)
Username: Prevost82
Post Number: 326
Posted From: 208.181.210.47
Posted on Wednesday, August 01, 2007 - 12:07 am:
Some of them use bolts instead of magnets, with the bolt head triggering the sensor.
Ron
