Michael Chappell (Loader10)
Registered Member Username: Loader10
Post Number: 8 Registered: 3-2007 Posted From: 70.165.25.168
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 02, 2007 - 9:53 pm: | |
Does anyone know what and how to adjust a ross steering unit. I see where to do the adjustment , but I don't know the proper way to do this..... |
Hans (Buellhans)
Registered Member Username: Buellhans
Post Number: 62 Registered: 2-2007 Posted From: 199.60.181.9
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 02, 2007 - 11:01 pm: | |
Ross steering gear is mighty touchy stuff been a while since I touched that stuff , whats the problem? |
Post Number: 9 Registered: 3-2007 Posted From: 74.193.175.186
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 04, 2007 - 4:04 am: | |
It has about 5-7 inches of slack. Makes for a very busy drive. |
Post Number: 691 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 04, 2007 - 10:35 pm: | |
Make sure that a lot of that play isn't in the other components of the steering system, as that is usually where that much play is found. |
Post Number: 10 Registered: 3-2007 Posted From: 74.193.175.186
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 05, 2007 - 4:46 pm: | |
It has new tie rods, king pins,center link, steering gear about the only thing left. |
Post Number: 697 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 06, 2007 - 10:45 pm: | |
does it have a small steering column to steering box driveshaft or does the steering column connect pretty direct to the box? |
bob swanson (Bob_swanson)
Registered Member Username: Bob_swanson
Post Number: 4 Registered: 6-2007 Posted From: 75.90.53.122
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 07, 2007 - 10:15 pm: | |
do you still need this. I can fax you any pages you need from their manual. send pm. i do not have a scanner. |
Post Number: 11 Registered: 3-2007 Posted From: 131.10.254.61
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 08, 2007 - 3:40 pm: | |
Bob, any info that you have will help. You can fax @ 318-456-8099. |
