OTR A/C Question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » August 2007 » OTR A/C Question « Previous Next »
William D. Watkins (Sivrtnge2)
Username: Sivrtnge2
Post Number: 122
Posted From: 70.11.146.250
Posted on Monday, August 06, 2007 - 2:48 pm:
It looks like I had an aftermarket O.T.R. a/c system. How would one go about checking the lines up to the front of the coach, if there is no compressor???
The way the lines are taped off, I think the problem was with the compressor. But, because I don't know how long the compressor has been removed, I thought it would be a good idea to at least pressure check them. I think this was the sanden type compressor because of the way the hoses hook up with a bolt threaded in the center. Please advise!!!
BILL
Username: Joe_camper
Post Number: 23
Posted From: 76.223.83.13
Posted on Tuesday, August 07, 2007 - 8:02 am:
We had or factory OTR A/C repaired when we bought our bus used and we had no idea how long the system vacuum was compramised. Moisture is the biggest enemy here. Ours has a large evap. for the bus and a second smaller for the drivers. After replacing both expansion valves rebuilding the compressor and replacing a hose along with freon we thought we were good to go.
All the air that was allowed to creep in over time caused the new expansion valves to plug twice more due to dirt and rust before the system began to function correctly.
My advice would be when you do check these lines try to THOROUGHLY blow them out with air or some equivalent to get out any undesirables, along with the rest of the system as well.
Put a vacuum on those lines to check them. I think that Prevost charged our system with 200+ pounds of nitrogen overnight to test but that was only after we had a complete system again.
(Message edited by Joe camper on August 07, 2007)
Username: Sivrtnge2
Post Number: 123
Posted From: 70.11.116.55
Posted on Tuesday, August 07, 2007 - 8:59 am:
Thanks Joe,
I might have mis informed you on the unit. It is an aftermarket dash air system. I will definately follow the advise of you and Nick.
BILL
