Post Number: 70 Registered: 3-2007 Posted From: 76.4.136.26
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 09, 2007 - 6:18 pm: | |
hey ya'll I am trying to find back-up lights to put on mci-8 that will not look like %$#@$$. what is opions of and brands of them. They need to be classy and BRIGHT thanks ya'll Gomer |
Bill 340 (Bill_340)
Registered Member Username: Bill_340
Post Number: 42 Registered: 7-2006 Posted From: 75.195.59.152
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 09, 2007 - 9:02 pm: | |
http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=TRUCK |
Post Number: 71 Registered: 3-2007 Posted From: 76.4.136.26
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 09, 2007 - 9:08 pm: | |
thanks bill I lost the address now I put it in whaer I won;t be a losing it gomer |
James Smith (Tomcat)
Registered Member Username: Tomcat
Post Number: 53 Registered: 8-2005 Posted From: 207.200.116.13
Mount two flood lights forward of the rear bumper, but above it's bottom level. Aimed to the rear and slightly down, they will light up the entire area behind your coach without blinding anyone. Not prone to breakage when mounted backwards either. Jay 87 SaftLiner |
James Stacy (Jimstacy)
Post Number: 91 Registered: 1-2001 Posted From: 75.41.4.228
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 09, 2007 - 10:50 pm: | |
BTW Most states require that a white light shining to the rear must only be powered up when vehicle is in reverse. No manual switch allowed. You won't get caught if you never forget to turn them off. Yah, I know, how do they get away with the "worklights" on pickups? An old cop rambling on. Jim Stacy |
Post Number: 1275 Registered: 12-2000 Posted From: 67.181.189.94
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 10, 2007 - 10:05 am: | |
Marvin - I saw one MCI awhile back with two fog lamps mounted adjacent to the back-up camera and blended into the top of the rear cap. If you want BRIGHT, then get a couple of Cibie E-code fog lamps. www.cibieusa.com FWIW & HTH. . .
Post Number: 87 Registered: 5-2007 Posted From: 64.40.223.242
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 10, 2007 - 11:34 am: | |
I have two lights mounted on either side of back up camera in my camera pod, switched up front on dash. They do provide needed light when backing up, work great. |
Post Number: 1964 Registered: 1-2001 Posted From: 75.108.76.56
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 10, 2007 - 2:47 pm: | |
I like them mounted up high so I can see overhanging branches when backing into camping sites. Also illuminates the whole area. Ruchard |
Post Number: 431 Registered: 11-2005 Posted From: 63.97.117.33
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 10, 2007 - 6:21 pm: | |
I'm going to install mine like Paul's so they work when the BU camera is on. If the monitor is on I'll know the BU lights are on. |
Post Number: 88 Registered: 5-2007 Posted From: 64.40.223.242
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 10, 2007 - 8:10 pm: | |
Gus, I have a seperate switch for the lights. Even though my camera has night vision it still helps if someone is guiding me in. That way when the camera is on during daylight the lights are off. Paul |
